All of a sudden (I have had this fax a while) and have not changed anything, it will only send for 33 seconds then tell me to try again and gives me a Error TX Report with time use 33 seconds, pages sent 3, result NG, please help this is so frustrating.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
Check wether it has a timer beeen set on it .i think there is a setting mis order tken place . if you have the catologue try to set the fax machine to a mode of priority to urgent or normal mode ond try it or else try to change the timer settings if it has
and let me know if it doesnt work
Posted on May 13, 2011
SOURCE:
Recieve error 334 when sending fax but i am able to recieve faxes
Error Codes: 332, 333, 334, 335, 336, 337, 338 ECM, 339 ECM, 340 ECM, 341 ECM, 342 ECM, 343 Definition
The remote fax machine might be defective.
Solutions
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
Error Code: 334
Definition
Solutions
Sep 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Product is telling me doc. is to long when i try to fax a paper also it will copy only the bottom portion of anything i try to copy help please
No there is problem with slow sensor flaper and pick up, feed and separation roller, clean it all, you may need to change the sensor flapper.
May 08, 2009 | Canon LaserClass 9000L Plain Paper Fax
Fax Will not send or receive.
Unplug the power cord for 10 seconds.
It is not detecting a dial-tone.
Jan 30, 2009 | Brother IntelliFAX 4100 Laser Fax
I have a dial tone, but cannot receive or send faxes
After trying everything, I reset the machine to factory settings (press Menu, then 7 for Maintenance). I then also changed the fax cable to the telephone socket. Despite a computer shop telling me that I need a BT to RJ11 cable (I think this is a modem cable), the correct thing is to use a simple telephone cable. The look exactly the same from the outside (both plugs), but apparently they are wired differently which may not be visible from the outside. Now it suddenly works again!
Jan 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
CANON IMAGECLASS MF4150
If you are using the phone while trying to send or receive a fax, it will not work.
There were some devices out that would allow you to do this, but they never really worked that well.
If you want to be on the phone, and send or receive a fax, you will need a second line for the fax machine, or you need to use a service like eFax (it sends a fiax like sending email)
Jul 28, 2008 | Office Equipment & Supplies
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
When I send faxes the reciever gets a different fax caller ID
Ring 13 2600. Tell them you bought it (NOT SECOND HAND) and you lost the manual, Explain the problem and they should give you an answer for free!
Jan 28, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Material I'm trying to send doesn't 'feed'
does it try to grab the paper?
do you hear anything happening before the beep?
The machine recognises that there is paper, then you should hear the communication, once it has the correct signal telling it the line is available for transmission it will feed the paper.
look at the tires and see if they turn to feed the paper, is there something in the way, do the tires turn,???
if yes clean with alcohol and try again, if the tires are too smooth then they need to be changed.
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Cannot receive faxes or do copies
If you still have your old cartridge reinstall it that will tell you if it is the cartridge or not. If you still have the problem,it could be the encoder.
Oct 23, 2007 | Office Equipment & Supplies
100 people viewed this question
k24674
Marvin
Marvin
