Question about Cameras
Printing Hi, we bought an Agfa AP2700 and printed the first 5 prints for which the paper was included in the package. Now having replaced the ribbon/cartridge a message appears on the screen " insert ribbon parameter card" Can someone tell me what this means as there doesn't seem to be any write up on this in the very scanty instruction leaflet that came with the machine. Thanks
  • angel41080 Nov 17, 2008
    exactly the same thing has happened to me and the instructions are useless - how did you overcome the problem? Thanks
  • crionescu1 Dec 31, 2008
    I experienced the same problem.
    When I replaced the demo ribbon with new one I got the message "Insert ribbon parameter card" and I couldn't fix this problem.
    Could anybody help us, please?
Hi,had the same problem, phoned the helpline, the fix is a new ink ribbon, basically it has run out of ink (or dried up)
Posted on Jun 09, 2009
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
Epson STYLUS DX4400
Have you removed the pull off tape from the top of the cartridges, it lets air in enabling the ink to flow, easy mistake!
May 27, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
Photo printing
If the printed output smears with a light touch, you may be printing on the wrong side of the paper. There is some photo quality paper that can be printed on both sides (it will say on the box if so), but most photo paper can only be printed on one side. Check the directions that came with the paper.
Apr 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
AGFA ePhoto 780c
Please do try http://static.agfa.com/digicam_scanner_drivers/ and http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/AGFA/AGFA-Digital-Camera-ephoto-1680-10.shtml and search there itself for the software u want
have a nice day
Jan 24, 2008 | Adobe Photoshop CS2 for PC
Cameras Logo
182 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
