Question about Compaq Presario Notebook
How to resolve this ploblem
I get this message when i'm trying to instar windows200 from my server ***Hardware Malfunction
Call your hardware vendor for support
NMI: Parity Check/Memory Parity Error
***The System has halted*** how can i resorve that?
    Sergeant:
  • 359 Answers
You have a faulty RAM stick replace the memory and this should fix your issue.
Could be a mainboard failure but I doubt it.
Posted on Aug 14, 2008
Hardware malfunction call your hardware vendor for
It appears you have one or more bad memory chip. If you have more than one try removing one at a time to see which is bad.
Jul 14, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Hardware Malfunction Call your hardware vendor for
The RAM in your computer has gone bad. If your computer is still under warranty, you should contact your hardware manufacturer/the store you bought the computer from for assistance, as this is a case of failed hardware.
Otherwise, you could try these suggestions to get your computer up and running:
Re-seating the memory:
  1. Turn off the computer, and unplug it from the wall. Press and hold the power button afterwards to discharge remaining electrical charge inside the computer- the last thing you want to do is zap yourself or other equipment.
  2. Open the computer case, and locate the RAM banks. Gently take the RAM out, then put it back in, re-seating the connections. remember to keep one of your hands on the metal portion of the computer case at all times- to ground yourself and to prevent from frying the RAM sticks you are working with.
  3. put the case back on, plug everything back in. Turn on the computer, and see if this fixed the issue.
Replacing the memory:
  1. buy/obtain new replacement RAM sticks for the computer.
  2. Follow steps 1-3 mentioned in the previous suggestion, replacing the RAM, rather than putting the same sticks back in.
If you feel uncomfortable with doing either mentioned above, or feel you do not know your way around computer hardware- do not try these steps!!!! Instead, consult with a techy friend or a local computer technician in the area for further assistance.
Good luck! hope this helps!
Dec 25, 2010 | Dell Computers & Internet
My laptop has crashed and gives the following message hardware malfunction call your hardware vendor for support NMI: parity check/memory parity error The system has halted
could be a defective Ram memory. or some bigger problem with the motherboard
follow this link how to replace or workaround with your problem.
http://support.microsoft.com/kb/315223
i hope this help.
Dec 18, 2010 | Computers & Internet
CODE ERROR 10
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10)Recommended resolutions
Here are some things that you can try to resolve this problem.
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
Feb 26, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
Hardware halfunction
Hi!
This behavior can occur if a hardware component malfunctions, or if there are damaged or incompatible drivers installed. As with VISTA!
To try to resolve this behavior, use the following troubleshooting techniques. Because Windows can display only basic error messages when hardware malfunctions occur, troubleshooting can be difficult. Most equipment problems center around the motherboard, the RAM on a motherboard or on an adapter, or the cache memory on a motherboard or on an adapter.
Remove any adapters that are not required to start the computer and run Windows. In many cases, you can start your computer with only the drive subsystem controller and the video adapter.
Let me know.
Feb 15, 2009 | Microsoft Age Of Empires II: Conqueror 2.0...
From the error report, it sounds like you have a bad memory chip (RAM).
If it's under warranty, contact Dell for a replacement.
If it is out of warranty, go to a vendor that sells RAM and replace it (such as www.crucial.com)
Jul 28, 2008 | Computers & Internet
HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED
Dec 07, 2007 | Dell Inspiron 6400 Notebook
Windows xp professional sp2
Motherboard or hard drive problem. That is my guess..
Nov 30, 2007 | Computers & Internet
Compaq Presario Notebook Logo
314 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
