Question about Estate TEDX640JQ Electric Dryer
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
We recently moved into a house with a wall unit that has 3 prong. Our estate dryer has 4 prongs....HELP
  • Anonymous Mar 30, 2014
    I have a 3prong plug and 4 prong socket how do I fix this
  • 5,911 Answers
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Posted on Aug 13, 2008
How do I change the 3 prong wall mount to a 4 prong wall mount for a dryer?
Since you are asking, I would not suggest you try it. 240 volts is deadly. It would be easier to change cord to 3 prong and then add grounding wire from back of dryer to cold water pipe. The 4th prong is a ground connector, new standard for safety. Your house wiring may not be set up for it, or it might be. Unless you know what you are doing, let someone who does do it for you. Be safe pls
Mar 06, 2015 | Dryers
Change cord on estate whirlpool dryer to fit outlet in wall
If this is an ELECTRIC dryer, the following link explains how to install either a 3-prong or 4-prong power cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If this is a GAS dryer, the standard color code for a three prong grounded plug is:
BLACK - HOT
WHITE - NEUTRAL
GREEN - GROUND
If you have any questions, please post back and let me know. I hope this helps you.
Jun 23, 2011 | Estate Dryers
Need to change out the wall plug to fit the dryer plug. The dryer is a 4 prong and to wall is a 3 prong.
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Mar 18, 2011 | Dryers
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
After conversion from 3 prong to 4 prong dryer wont work
YOUR FOUR WIRE CORD IS AS FOLLOWS RED,BLACK WHITE AND GREEN ON YOUR DRYER YOU HAVE FROM LEFT TO RIGHT 123 CONNECTIONS THE TWO OUTERMOST(1 AND 3) ARE HOT LEADS SO HOOK RED TO 1 AND BLACK TO 3 NOW HOOK WHITE TO 2 AND THE GREEN CAN BE ON THE TERMINAL COVER SCREW OR NOT AT ALL BUT BE SURE IT CANNOT COME INTO CONTACT WITH RED OR BLACK
Apr 27, 2009 | Estate TEDX640JQ Electric Dryer
Estates dryer by whirlpool has a 3 prong plug. the wall has a 3 prong w/an L shape. where can I get a wall switch to match the 3 prong without the L shape as this is a straight shape
Home Depot, Lowes, etc will sell these type plugs in the electrical section. If installing yourself, be sure you get the wires in correct positions, let me know if you need info on that.
Nov 16, 2008 | Whirlpool Dryers
Estate TEDX640JQ Electric Dryer Logo
383 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
