Question about GE Washing Machines
Turning on the water valve fills the washer with running water even when the washer is not turned on. was the washer incorrectly installed?
  • 958 Answers
Probably not.
you could have a defective water inlet valve that lets the water in even though there is no power to that valve.
check that valve, remove it and blow unto it. there should be no air passing thru.
i hope i was able to help...
cheers,
drcool
Posted on Aug 13, 2008
I recently installed new fluidmaster fill valve. Now when i try and turn valve from wall on the water flow from valve shuts off before i can get valve all the way on. Even if i turn it on slow it will...
You have a water restriction, a fluid master can be taken appart it has a cap on top that will pop off that conceals a washer where water comes up.
First turn water off and remove cap and barely crack valve and flush out with cap and washer out just look at it good so you will know how to put it back together.
That way it let you know if the valve is where the problem is. You could take supply line loose from bottom of tank and turn valve on run some in a container to flush out any trash in line.
May 15, 2010 | Home
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool duet front loader
Washer should fill, remove hoses, check screens in hoses and or valves on machine for clogs. Verify water valves at the source are turned on. If all this checks, you need new valve installed on your washer.
May 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Washing machine
it needs a new water valve
Nov 16, 2007 | Kenmore 22422 Top Load Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
24 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
