Question about RCA Televison & Video
Color will not adjust on projection tv
I have a phillip manavox projection tv that is a friend of mine, it was made in the year 2000.i do not have the model no# on hand. the problem is that i try to adjust the color in the television, but the color will always adjust to the extreme. i can never get the red out of it. it has red ghosts in most of the channels, and some just be blurry. i can never seem to get the color crisp. i also have tried to use the menu and try to get the color right but it seems that none of the items work. the tint, brightness,color or any of the items seem to work well. they work a little but not much. when i adjust the color from the back it seems to be too much darkness or whiteness. also what are the top row of turn knobs for. i know that the bottom three are for red blue and green color but what are the top three for.
  • vljenterpriz Aug 13, 2008
    i will be doing the job myself. i know how to solder. the md# is9p5034c102
  • vljenterpriz Aug 15, 2008
    i have paid dan and gave him follow up information but i have not been given any finished information on where to look for or what to do with the convergence chip.
  • 4,234 Answers
From the sounds of it, you have a convergence problem. This can be fixed in the home without too much trouble if you feel you are comfortable with soldering. Can you please post the mdoel number? That way I can provide you with the parts that will need attention. Also please indicate whether or not you wish to attempt this repair yourself. With this additional information I can either guide you through the repair or give you a ballpark cost for the repair.
Thanks,
Dan
Posted on Aug 13, 2008
I have a model 60PP9202 60" Phillips projection TV that has color convergience problems. It started a few years ago when the TV wouldn't turn on at all. After unplugging it for several hours, it...
Below is a link I have included. This is a site I use to repair parts in projection tvs. The kit includes detailed instructions on how to repair it yourself. If this told you something you did not know rate this solution as very helpful as I do this here for free.
ALSO, if you have questions reply to this posting and I will assist you--I am here to help.
http://www.tvrepairkits.com/xcart/product.php?productid=23609&cat=3647&page=1
Jan 05, 2011 | Philips 60PP9202 60" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Color projection tv
Adjust the top left knob back down till the color comes back
Feb 25, 2010 | Philips Televison & Video
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
43 inch phillips projection t.v
There is no bulb or color wheel in a standard projection set. The standard projection set has convergence output IC's that correct the 3 colors around the edges of the picture. If one of these IC's burns out then one color may sag toward the center at the top. The defective convergence IC will have to be replaced and the convergence circuits realigned and that should be done by a qualified tech.
Aug 07, 2007 | Philips 43PP9202 43" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
