Question about Zebra 170XiIIIPlus Thermal Label Printer
Error condition Hi. i have a problem with one of my zebras, its a 170 xiIII plus one; after fix some other problems like ribon out and head open i can't get fix an error condition p3/p5. can any one help me?
  • hgonzalez86 Aug 13, 2008
    nop i didn't; if you tell me how to restore the default values i'll do it.
    New Friend:
I had a similar situation with Error condition P3/P5. One of the ribbon guide bar screws had loosened and allow the ribbon to drag on the ribbon sensor. After trying the alcohol wipe trick mentioned on this site the error condition stopped. Thanx for the tip....
Posted on Dec 10, 2009
I did clean it yesterday. so it has to be damaged.
Posted on Aug 13, 2008
It's done but it stays under the same condition. i think this one is more related to some hardware problem. some thing like a sensor or so.
don't you think?
    Problem Solver:
  • 25 Answers
Have you tried to reset the printers defaults?
  • Anonymous Aug 13, 2008
    I do not have the EXACT procedure for your printer.
    The printer that I have reset is a different model.
    They may be similar.
    My book says:
    Press SETUP/EXIT 2 times
    Use the PLUS (+) or MINUS (-) to scroll through the SAVE CHANGES Choices.
    When LOAD DEFAULTS displays, Press SETUP/EXIT.
    I cannot remember if machine restarts or not.
    This is a link to Zebra 170XiIIIPlus information.
    http://www.zebra.com/id/zebra/na/en/inde...
    Canned air is always helpful with sensors. NEVER shake CANNED AIR. ALWAYS keep canned air upright.
    You may have ink on a sensor. do you have small squares of alcohol wipes? (First aid kit?) be careful cleaning sensors.
SOURCE:
Zebra Z6m Error Paper Out
sensor not working or dirty in the feed path id suggest
Dec 27, 2017 | Zebra Z6M Plus Thermal Label Printer
Error condition, heads open, ribon out
This is usually a sensor problem, make sure it is dust free and no labels are stuck around it. Check the label and ribbon paths are correct and switch off and on again.ronanjd_0.jpg
Mar 10, 2011 | Zebra 105SL Thermal Label Printer
I have a Zebra 110 XiIII p it does print different size bar codes
Keeping up with the Drivers is a very good idea, it will fix little problems that come along from time to time. Try resetting the printer defaults by entering the menu system and exiting, at piont of exit don't save permanently but cycle around to load defaults and exit. Go back in and set the printer up again, this time exit saving permanently.
Jan 21, 2010 | Zebra 110XiIIIPlus Label Printer
Have X3 Zebra 140Xilll printers. These printers will stop printing with a message "Error condition Paper out". But the paper is loaded. Everything seems fine. What can I do? Thanks Steve Rolland
Check and clean the sensors, also the reflective surface. Make sure there are no lables stuck to the reflective surface. Use Isopropyl Alcohol to clean.
Jan 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Error condition ribbon out
is dirty ribon end sensor, clean with a soft cotton swab, may help.
Jan 14, 2010 | Zebra 110Xi III Plus Thermal Printer
Hi, Is it possible to run two Zebra xiIII's from one PC?
You can run as many Zebra printers as you have the connections to service with unless you are using a software program that limits you. Some of the LabelMatrix products from Teklynx will sell you 'seats' of software licenses. You can usually increment in 5's. Check out your software manual.
May 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
XiIII Latest Firmware
I know when I was going through the zebra website I seen a bunch of firmware downloads. Once you are on their home page just click on downloads, then you should be able to find them.
May 07, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Hi, I have a zebra 110 xi||| plus which is printing extra labels.
Did you design the label? Do you have any control over the label design? This is usually a sign that the printer is trying to excede the page limit (usually by one dot row) and is going to the next label to finish. By making the label length slightly smaller, you can stop this.
Mar 20, 2009 | Zebra 110Xi III Plus Thermal Printer
Printing error condition
First clean the sensor tag and sensor head open and tape. Then perform a calibration label pressing the PAUSE and FEED buttons and turn on the printer, release the keys until it starts to move the label. Wait until you are finished and ready to print.
Feb 27, 2009 | Zebra Z6M Plus Thermal Label Printer
Zebra 170XiIIIPlus Thermal Label Printer Logo
1,664 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
