Question about Icom IC-R5 Handheld Scanner
No fm reception
No fm modulation but seems to recieve am broadcasts
  • 120 Answers
Look for a button called mode and press that, it should switch it to fm narrow (communications) or fm wide ( fm broadcast stations) or am
Posted on Jan 17, 2009
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately ..fm is a totally different band obviously fm isn't being affected by that whole home broadcast unit..you're lucky! on that count
Dec 12, 2013 | Denon AVR-2307 Receiver
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
Kdl-37w55/57 sony bravia problem is every so often the picture seems to stutter,delay best way to describe it. Any ideas
hello, try tightening your antenna connection this happens when your signal input cable is fualty or loose check that first. then try all other connection that come from your cable,sat reciever or antenna hook up. if your using a digital reception device or digital antenna check those connections to. and be aware that digital reception has interuptions and they depend on the distance between you and the digital signal broadcast station, sometimes storms and atmospheric conditions may cuase a brief lapse in the signal.(stutter) what are you using for a reception? satelite, cable or a digital antenna? hope this helps
Jun 04, 2010 | Sony Televison & Video
Where is the antenna for 2001 chevrolet cavalier? I just purchased a FM broadcaster for my mp3 player and the cavalier radio will not pick up the signal.
it's at the rear of the car on the passenger side -- many FM broadcasters are very low power, but even so the Cavalier is a small car and shouldn't have any problems, I have one that is used in a '02 Sebring with no issues -- if you have problems with reception of normal broadcast radio, the problem may be with a connection (either at the antenna or back of the radio) also ensure that the radio is on the same frequency as is being broadcast.
Jan 10, 2010 | 2001 Chevrolet Cavalier
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
No AM radio, very weak FM radio reception
i would pull set out and have a look at the printed circuit from the aeriel to where ever it goes to in the circuit board ,if i couldnt repair it ,then i would have a nice drive to carrefour(hypermarket) and buy myself a belson which has usb/sd card/cd and they do one with blue tooth all for about 100€ and fit that .who needs a cd changer when you can put a 2 gb sd card in that can hold 40 +cds or plug your i pod in
Feb 16, 2009 | 2000 Honda Odyssey
Ipod shuffle, Xm reciever, Fm modulator
Yes it Does. The Ipod will not work in this Application. The FM Modulator is Programmed to Accept only Certain Connections. Please Rate My Response! Thanks!
Jan 31, 2009 | Apple iPod shuffle Second Gen. Silver (1...
AM Reception
what kind of car are you driving. on some cars the antenna need to be extended in order to recieve am reception.
May 27, 2008 | Kenwood KDC-222 CD Player
Bad reception
I see you've already read the "Troubleshooting" section of the manual! The only other things I can think of to check would be the actual connection between the radio (aka head unit) and the antenna. It's usually just a press-fit connection behind the radio, but if it's loose, corroded, or is touching some other metal, it could affect the reception.
There's also the small possibility something changed at the transmitter tower for the radio station. That happened in my area once, where they changed the direction in which most of the signal power was being broadcast. Westside reception got better, eastside reception got worse.
Mar 13, 2008 | Kenwood KDC-MP235 CD Player
Icom IC-R5 Handheld Scanner Logo
232 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
