Question about Whirlpool GH7155XHS Microwave Oven
Micrwave Not heating up
Hi-
Our microwave is more then 3 years old. It looks to be working, but the food is not heating up, as well as the sound while using the micriwave has gone up..
Thanks
  • pkoneru1 Aug 18, 2008
    Yes, Both the light and the turntable come on. But we sense a burning smell when its on.
    A little louder then usual might be.
    GH7115xhs - That's the model number.
    Would it be easy to fix it on our own. Like replacing any part. Becuase some of the parts are still under warranty , but not the labour.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
    Do you have the model number?
  • Whirlpool Master
  • 9,174 Answers
I would suspect (in order) a shorted high voltage rectifier diode, a bad magnetron, or a bad high voltage diode.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 18, 2008
SOURCE:
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
When you press start the microwave starts with a low hum and sounds like a bearing or fan is vibrating, micrwave still heats up and works just runs rough. Bruce
Ther is a loose peace of metal in the magnetron, it is not a big worry, it's just noisy, i have a noisy microwave and it is working fine for 10 years now, if you use the defrosting mode you should hear the noise (on and off) because in the defrost mode the magnetron energises on and off, it could be the cabinet vibrating as well look for loose peaces of metal
Jan 04, 2011 | GE JVM1850 1000 Watts Microwave Oven
Microwave no longer heats; makes no sound or buzzing noise
hi..it sounds like a magnetron problem.It might have
got into damage.
check this out..
thank u..
kindly rate my response..
Jun 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
3 year old unit, oven works, microwave does not
hi,
You may need a new magnetron, contact sharp or the store you got it from; most microwaves have a 3-5 year warranty on the magnetron. If it's not in warranty, find a good appliance repairman, this is a difficult and dangerous repair job.
Apr 03, 2008 | Microwave Ovens
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Mar 21, 2008 | Microwave Ovens
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Cooking
I would say the high voltage diode blew.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can get Sharp parts from Tritronics at http://www.wehaveparts.com
If it's not the high voltage diode, reply back for further help.
Oct 24, 2007 | Sharp R-1610 Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
129 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
