Question about PANDIGITAL PANSCN05 Film Scanner
How do I scan negatives? - PANDIGITAL PANSCN05 Film Scanner
    President:
  • 2,992 Answers
You can try scanning negatives the same way you scan prints, but the results may not be great. Scanners that are designed to scan negatives usually have some way to put light behind the negative to make sure it scans with enough contrast. They often also come with special holders for negatives. I don't know if your model was specifically meant to do negatives, but you can't hurt anything by trying.
After you scan a negative you need to convert it to a positive. The scanner may have come with software that can do this. If not, IrfanView is a free program that can do that as well as much more. It's a great general-purpose image viewer, so it's worth downloading in any case.
Posted on May 13, 2011
SOURCE:
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
Can you scan negatives on a flat bed scanner?
You can only scan negatives on a scanner that has a second light source in the lid of a flat bed scanner. This light shines a light through the negative and the main light source under the glass is not switched on for negative scanning.
Jun 02, 2011 | HP OfficeJet J4580 All-In-One Laser...
Negative are scanning as negatives and are not converting to a photo??? PLease help
Negatives are supposed to scan as negative as it displays what you scan. Try going into the image/edit menus and find the effects/filters and choose negative. If you apply the negative effect/filter to your negative image it will become a positive image. Hey presto!
Apr 03, 2011 | Arcsoft PhotoImpression® 6 Full Version...
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
Scanning Size
Do not try to change the scan size, change the resolution. The window that appears when you want to scan should have a resolution (DPI) area that can be changed. IE: 300 DPI to 800 DPI. This changes the picture size.
May 16, 2009 | BenQ ScanWit 2720S Film Scanner
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Scanning Medium Format negatives
The lamp on the scanner (Cano Scan D1250U2F) is too small for medium format negatives.
Jul 19, 2008 | Office Equipment & Supplies
CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Jan 27, 2008 | Canon CanoScan 4400f MultiFunction Color...
PANDIGITAL PANSCN05 Film Scanner Logo
497 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
Rick Ostrowski
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
