Konica 7030 error code f-28-3 - Office Equipment & Supplies
  • EngineerKhamis May 09, 2009
    ERROR MESSAGE F-28-3 IN KONICA MACHINE
4 Suggested Answers
  • 158 Answers
SOURCE: call factory code F-28-3
ts corona is shorted could be either the corona wire is broken or the terminal is arcing
Posted on Oct 24, 2009
ollysss
  • 7 Answers
SOURCE: KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Posted on May 21, 2008
  • 6 Answers
SOURCE: Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
Posted on Aug 09, 2008
I huv a konica 7030 then i encounter a problem error F-52-1 code, can you help me what Im going to do! thanks & Godbless
Read the manual for trobule shooting solutions: www.kontrix.pl/folders/16625810454b7558e90d86b.pdf
Jun 17, 2014 | Office Equipment & Supplies
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
F-28-3 knoica error
F 28-03 The toner separation ON/OFF operation has been performed 5 consecutive times since the separation trouble detection signal was detected at start of toner separation.Please check the HV2 unit,the transfer/separation corona unit.If there is a paper in copiymg proces when this jam occurs the machine stops after completion of copied paper ejectiom.
Oct 01, 2009 | Konica Minolta DiALTA Di200 Copier
Call factory code F-28-3
Jun 15, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
1,372 people viewed this question
jasbo
jasbo
