Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Spitting Out Debris
My Dyson dc07 is picking up dirt - you can see it in the cannister - but it's spitting out crumbs, rice, etc back onto the rug. I can feel it hit my feet. So it's not doing a great job, just moving the crumbs around. I've cleaned the filter, wiped the inside, and my husband has checked for blockages - and the brush is spinning - any other ideas?
The beater bar (rotating brush) can kick back crumbs if the suction is not at 100%. This can happen if the vacuum has been used for a number of months without a thorough cleaning.
First thing is to not let the dirt canister get too full. The more full it is, the more dirt is sucked into the "cyclones" which are meant for only fine particles, not big pieces of dirt.
I'd then check your elbow hose connections (the ones that snap out easily). Then check the Hepa filter. When I lost suction with my Dyson DC07 the Hepa filter was a mess. But the inner cannister seemed to be really dirty also, so I dismantled it (this will void the warranty) and washed it out under the kitchen sink. Do not try this unless you know exactly what you're doing, but mine was an extreme case, as the Dyson was used by family members for about three years and they probably never cleaned the Hepa filter, etc.
Now I'll at least wash the Hepa filter (and housing) twice a year, as Dyson recommends.
Posted on Aug 26, 2008
    Problem Solver:
  • 8 Answers
The hose from brush go to the bag need to check for blockage you have to open there hose to clean
Posted on Aug 22, 2008
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
Dec 11, 2012 | Eureka True Clean Upright Vacuum (Yellow)...
Dyson DC25 is barely picking up, but what it is picking up is not going into the cannister,
Your problem is posted in the wrong category, so probably no-one reading here (Telescopes and Binoculars etc) will have the solution.
I do know that Dyson maintains Tech Advice lines worldwide. Look here
http://www.dyson.com/
select your region, then look for a Tech Advice number you can ring
Jun 10, 2012 | Dyson DC25 Ball All-Floors Upright Vacuum...
Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Mar 13, 2010 | Vacuums
Vacuum throws dirt onto machine and not in it
Hi its Darran at Dyson.
It sounds as though your machine is blocked. This is why the dirt is being dropped back out on your floor and also why the bin is not filling up.
Simply follow the blockage procedure in your user guide, or on our website at www.dyson.com. Visit the support section and you will be able to download a user guide. This will also allow you to confirm if the machine is correctly assembled and that there are no parts missing on disconnected.
Kind regards
Darran
Dyson Customer Service
Mar 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a purple dyson dc07 is the cannister supposed to spin or not?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The debris collected in the bin doesn't always spin. Sometimes it gets stuck to the side, or just held in place by gravity. This does not affect performance.
If you have any further concerns about your Dyson DC07 vacuum cleaner or feel that the machine is nor performaing correctly, please check out the online Support at www.dyson.com or call our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
<e>Found this information useful, why not tell everyone and leave us a testimonial. </e>
Jan 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Shuts off in upright position and spitting dirt back out
it is a blockage. Dyson cuts off in this case to prevent overload. Also leaking dirt indicates blockage. Strip everything out you can. Remove foot plate on base and check for hair or fibre blockage. it may be small and in an odd place.. seek and ye shall find. If not, return to dealer for service. Good vacuum though.
Sep 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I open the dirt cannister on a dyson animal (purple) so I can empty the dirt out?
This is fairly easy. Click on the button at the top of the hand above the cannister. It's a purple button and the handle faces the front and says Dyson on it. This separate the cannister from the body.
Next, hold the now full cannister above a trash can and click on the red button which was below the purple button (but hidden when it was attached).
May 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
Not picking up fuzz
I've had a similar problem with my DC07 Animal, although there WAS suction and the machine seemed in otherwise good condition, the vacuum seemed to be working normally, yet very little was vacuumed up. I would go over and over sections of carpet and get very little debris in the container. In my case, the cleaning brush roller bar was competely covered in debris (hair, dirt, string, stuffing from our chewed up dog toys, etc.). I removed the bottom cover and manually removed all this debris from the cleaner/brush roller, reattached the cover and it worked like new with great suction.
Apr 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Animal
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Jan 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
1,035 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
