Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
  • 112 Answers
If speeds still slow go int options on bitcomet and choose TCP/IP limit and change this to around 350.
Posted on Sep 14, 2008
    Problem Solver:
  • 35 Answers
You can check a site for speed site to help.
last option call the survive provider
Posted on Aug 13, 2008
Bitcomet listen port is blocked
You need to forward the specific port bit comet uses to listen,in your
router.To do this follow the below steps.
1) Go to this page
2) Scroll down the page and search for your modem/Router and
click on it.
3) Select the aplication from the list,in this case Bitcomet.
4) Now follow the step-by-step guide on this page to successfully forward your bit comet port.
Once you have done that restart your bitcomet and the listen port should now turn green indicating that it is open and functioning properly.Hope it helped.
Nov 21, 2010 | BitComet
Im not sure how to forward ports so i can download faster, at the moment im going at a slow 0.5KB/s ..... very rarely it jumps to 150 KB/s for a few secodns then falls back down again, peopel tell me to...
The speed of the download depends on how fast the computer that is holding the file(s) that you want can "send" the files.
Imagine one fast-food worker trying to serve 8 or 32 customers at the same time -- no matter how fast the worker is, everybody will get "slow" service. There's nothing you can do, at the order-pickup desk, to get "faster" service.
Similarly, "port-forwarding" is not the CORRECT answer to your downloading problem.
If you try to download something from a "fast" server (e.g., the latest version of Apple iTunes software), do you get "good" download speeds? If so, your computer and your router are working fine.
Sep 24, 2010 | Computers & Internet
Forwarding ports
Port Forwarding is explained indeepth by the torrent companies help FAQs section,
Heres a link that may helps you too....
In the Admin function you can accept the ports if you have the correct servers address's
You must add them to your firewalls permission settings and then try the test again,
Note ,
Even with Port Forwarding set up,
you will also require the correct band width and downloader from the torrent site,
Bit Comet and Bitcomet Excelerator
The downloader and the high speed function,together.
Hope this helps,Misterdj
May 03, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Just connected talktalk router to pc but when i go onto bitcomet to download music,i seem to be i still need a modem.
R U the Administrator of the WRT54G Router If not then ask to ur Administrator to unblock the site preference
then go to the WRT54G Router configuration page & Check for Access Restriction>Internet Access Policy
Apr 13, 2010 | Linksys Wireless-G WRT54G Router
Listen Port of TCP: 2869 (Blocked by Firewall/Router) how do i change nat router settings?im blocked when usin bitcomet software
try to disable ur firewall setting, enable nat, and rip
try set port forwarding to port 65535, dont forget to set bitcomet port 65535 too
Oct 08, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Need a port opened to speed up downloads
Hi. It really depends on what type of modem or router you are using to open up ports. Also if you are using an application for downloading such as Bitcomet, you need to find out what port or listening port is currently configured on Bitcomet. for example, the listening port on Bitcomet is 4545, then you have to open port 4545 on your router or modem.
You also need to make sure that your modem or router has port forwarding features..
you may also visit this link for instructions on how to forward or open ports to different types of routers...
May 10, 2009 | Computers & Internet
Yellow light with bitcomet 1.10 using xp and netgear dg834g
go to your router setting and try to disable all firewall, if still not work, check your port forwarding setting, it could went wrong, different router have different name for port forward. must set bitcoment port ..let say 65535 and set port in router 65535.
Mar 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Firewall and NAT router configuration/Router problem????
set a port forwarding on your router.
the port you open on port forwarding is the port you are going to use on your bitcommet
Mar 23, 2009 | Computers & Internet
Downloadspeed is low
to accelerate both download/upload speed delete all temp files and make clear cache everyday finaly test ur speed im sure would be faster.find here ur speed
Mar 21, 2009 | Computers & Internet
Listenning port bit comet
BitComet requires you to be able to receive incoming connections. If you're behind a NAT router but don't have port forwarding configured properly, incoming connections will be stopped by your router (won't get to your computer).You need to configure port forwarding, so your router knows that the incoming connections are for BitComet and will be allowed through (= forwarded) to your computer.
There are several versions of your router:
DSL-2640B, DSL-2640Bv2,...
Go here, scroll (almost all the way down) and find your router model.
On the next page, skip the advertisement (upper right corner) and look for BitComet.
Simply follow the instructions on that page - they are precise and correct.
In general: You can use ANY port, but I would prefer a listen port between 49152 and 65534 because they're classed as "Dynamic and/or Private Ports" by IANA, so nothing else should be using them by default and they're not the standard ones blocked by ISP's or trackers, but - as I said - you can enter any other port you wish.
If you have any more questions, just come back and let me know - I'm happy to help.
Good luck & thanks for rating!
Mar 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
128 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
