WILL CONNECT TO WIRELESS BUT NO INTERNET OPTIONS. ONLY ON LAPTOP WILL WORK AT A TIME
    Brigadier General:
  • 6,966 Answers
On your post "WILL CONNECT TO WIRELESS BUT NO INTERNET OPTIONS" this would be a configuration/settings issue more to do with TCP/IP. Pls post back what modem and your ISP (provider).
On "ONLY ON LAPTOP WILL WORK AT A TIME", do you mean you would want to use the Internet on more than one computer? If yes, then you would need a router to share the internet connection.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
No wireless connection suddenly. internet only works by cable in laptop and home hub
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Jan 15, 2013 | Toshiba Satellite Computers & Internet
No wireless download
Jan 15, 2013 | Computers & Internet
How i do keep my wireless switched on
click start Control Panel - Network Connections - right click on 'Wireless connection'
hope this helps
Sep 26, 2012 | Computers & Internet
I Have 3 PC's. 2 desk tops and 1 laptop. My desktops were working fine but laptop wont load internet. It says it connects to M10 router but cant find internet. Reset everything and tried again, Same...
Title: Can not access internet by other laptop
Open control Panel and go to Network and Internet Connection.
Open it and select Network Connection
After that you see your networks , select and Right Click on it and go to Advance Tab
In Advance tab you just see a option like "Allow me to share my network"
Click on that option , apply and ok
After that 1 dektop connected with another by LAN and Laptop connected with 2nd desktop By use of LAN cable
it call Series Connection.Like--1st desktop--->2nd Desktop--->Laptop
Otherwise Bring a HUB and You can access internet
Now you can access internet on both laptops
May 07, 2011 | Cisco Valet Wireless Hotspot (M10)
-unable to connect to wireless -unable to open internet explorer msg states "unable to connect due to error on this site" (yahoo) -Is there a reset botton for wireless -Called my internet Co,...
Your problem may appear from a not properly enabled WLAN card.
Make sure the Wi-Fi swithc is in ON position and on your laptop keyboard try the FN+F8 combination to have displayed the wireless card status. The WLAN card has to be ENABLED to be able to connect to the Internet. The combination done will make appear on your display a window with some options available; choose that option that enables your wireless card.
Also check in your computer's DEVICE MANAGER if your WLAN card is working properly. To do so follow these simple steps:
1. START and click on SYSTEM;
2. in SYSTEM option click on DEVICE MANAGER;
3. on DEVICE MANAGER option go at NETWORK ADAPTERS and see if there your wireless card is indicated and it shows that it is working PROPERLY;
4. if an UNKNOWN DEVICE is indicated then try to find the right driver for you notebook model and WLAN card model;
5. install the driver then REBOOT and recheck in DEVICE MANAGER if your WLAN card is displayed properly this time.
Mar 02, 2011 | Toshiba Computers & Internet
Mercury USB laptop connector with AT&T Service
try connecting with a cat5 cable instead of using the wireless. It is possible your problem is your wireless connection and not your service provider. Make sure your ether net connection is not disabled.
Sep 06, 2009 | Sierra Wireless Aircard 860 PC Card...
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
No internet connection on my Laptop Wired or Wireless
right click your icon in taskbar
click wireless connections a box should come up
highlight the connection then click connect
if nothing shows in box on left side click refreh list you may need to this a few times when a connection appears highlight click connect
if that did'nt work then control panel network connections right click your wireless connection if you see enable then click if you do not see enable then click repair
your ethernet driver for direct connection is probably not setup
try the first 2 options let me know if they help
Jan 11, 2009 | Acer Aspire 5050-3242 Notebook
Problems connecting to internet on laptop
check your IE internet connetion settings follow ff. steps.
1. open Internet Explorer browser
2. go to tools, internet options or options
3. under options, select "connections" tab
4. under connection tab, select "LAN settings"
5. under LAN settings check if "Automatically detect settings" is mark check if not mark it check.
6. click apply to save your settings and click ok
7. close your browser and open it again
if you still having a problem,
try this steps to chek your wireless settings
1. rigth click the wireless network status bar near desktop time & date
2. select status
3. under status, select Properties
4. under properties, select TCP/IP settings and click properties
5. check if "Obtain an IP address Automatically" is selected if not select.
6. click also obtain DNS
7. save your settings and close the properties
8. after saving, wireless will reconnect
9. open your browser for Internet
hope this will help you
Dec 16, 2008 | Linksys WRT160N Wireless Router
Purchased new laptop from Wal Mart @ christmas. initially connected to internet wireless and hard wire. now pc says it is connected but will not display any pages....is this a personal settings problem?...
it's more a browser issue, actually..
if you're on a wired connection or wireless, your laptop will let you know. Check in bottom of tray, to see that you're connected..
if so, go to browser(IE) and check Internet options/settings to ensure that you have active connections with those network options.
get updated printer drivers here, just in case
Mar 04, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
