Question about Canon PIXMA MP600 all-In-One InkJet Printer
Help i can't print
Hello my computer says arror code 5100. what do i do??
  • 10,594 Answers
Please mention model number and brand name of your printer to help you out.
Posted on Aug 14, 2008
  • Shahid Electronics
    Shahid Electronics Aug 14, 2008
    Hello, I'm still waiting Model and Brand name of your printer to provide info to help.
    Shahid Electronics Aug 15, 2008
    hows printer now? still shows error code 5100 ? let me know please.
    Scholar:
  • 133 Answers
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Tip
Service manual for Dell inspirion 1100, 5100, and 5150
Hello,<br /><br />Download the service manual for Dell inspirion 1100, 5100, and 5150 by simply click the below link.<br /><br />Note that the manual is in PDF format, so you need to have Adobe Acrobat reader already installed on your computer.<br /><br />Also, your computer configuration speed will determine how fast the service manual will load. Wait for the service manual to load completely before scrolling in order to avoid it hanging.<br /><br />It is advice able that you print it so that you can have a hard copy. Its usually strenuous reading from the computer.<br /><br /><a href="http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF%20">http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF</a> <br /><br />Good luck.<br /><br />
on Dec 28, 2010 | Computers & Internet
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
I get an error code 5100. Printe does not start to
Hello Gurmi,
It may be that you need to clean your timing strip. (Download the manual from the usa canon website to learn more about the timing strip.)
Also, if cleaning the timing strip does not help, you may need to lubricate your purge cap. The purge cap is the white sliding mechanism that the printhead parks against when not in use.
1. Get yourself some white grease.
2. Remove the right printer panel to gain access to the purge mechanism.
3. Do not get any grease on the wipers or the black caps!
4. Moisten JUST the purge cap with the white grease.
Let me know if this solves the problem! Thanks - ambssdor
Dec 11, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 5100 on canon mp 160
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Hope it do for you
All The Best: Pineworks
Nov 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
Acer 5100 motherboard problem.
To list all of the specifications for your Aspire here would take too much space.
You can download the manual directly from Acer for your 5100 series notebook. The manual will provide you all of its specifications. (Click on the link to open Acer's web site);
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Once the site opends click, Driver Download located at the left side.
Under, Select Product Family click Notebook. (Not Netbook)
In the next window click, Aspire.
In the third window scroll down & click on, Aspire 5100.
Click the Document button. Lastly, click on the white arror to download the manual. File named: AS5110_5100_3100-ENG-OLM_0616.zip
If you want to replace your current board. You can go to Ebay. This board includes your money back: http://cgi.ebay.com/Acer-Aspire-5100-MotherBoard-LA-3121P-HCW51-CR_W0QQitemZ220479374891QQcategoryZ158887QQcmdZViewItem
New 5100: http://www.google.com/products/catalog?hl=en&source=hp&q=Acer+5100&um=1&ie=UTF-8&cid=1680502998843797821&ei=H56zSv3rFtTYlAeQ76T9Dg&sa=X&oi=product_catalog_result&ct=result&resnum=5#ps-sellers
Taking apart Acer Aspire 5100 laptop
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Hope you find this helpful!
Cheers
Mike
Sep 18, 2009 | Computers & Internet
Have an MP460 and cleared a paper jam only to have the error code 5100 pop up and stop everything from printing
You will should be able to find information on that error for your printer by entering "error 5100" without quotes in the search box here. Then press Search. Then choose result 1 and follow the steps. Each step will have more detail available by click that steps link.
Hope this helps. Please remember to rate this information.
Thanks
Jun 04, 2009 | Canon Pixma MP450 All-In-One InkJet...
How to print from Acer Aspire 5100 Laptop
have you tried uninstalling the software and then reinstalling? I had same problem and that seemed to fix it for some reason.
Jul 06, 2008 | Acer Aspire 5100 Notebook
Error code:1/-3/11200 see doc #5305
hello, when i try to open up some file in my pics i receive this arror. Can you please help me
Mar 24, 2008 | Cameras
Canon PIXMA MP600 all-In-One InkJet Printer Logo
62 people viewed this question
old marine
old marine
