AMP PROBLEM MY AMP KEEPS BLOWING ALL FUSES CAN YOU HELP.I FIT NEW AND TURN ON IT IS OK.THEN TURN ON CD THEY BLOW.HAVE TRIED TUNER NO SOUND BUT FUSE DOES NOT BLOW.COPLAND CSA14
    Champion:
  • 232 Answers
Check ur speakers they can cause the short with vol
Posted on Aug 15, 2008
CTSY fuse keeps blowing
ok have your replaced any bulbs? i have found putting bulbs in wrong or just being a bad light bulb can blow fuses. try replacing all bulbs with new ones. its cheap and it could be the problem
Mar 18, 2013 | 2008 Chevrolet Silverado 2500HD
Amp fuse keeps blowing when car is turned off
It sounds like that fuse is supplying power to more than just the amp and is being shorted out in the START mode. Normally I would think the power to the sound system would be cut off by the ignition switch in the START mode. Try to find out what else that fuse supplies power to. You can disconnect suspected trouble areas to see if that helps locate the source of the fault.
Feb 16, 2013 | GMC Cars & Trucks
Is there anyone in the Fort Worth Tx area that can diagnose / repair an amp on a 1015 OMT Wurlitzer
You may want to check your speakers first if it's blowing the fuses. I have found that either open or shorted speaker coils will cause that. Try replacing the fuses and substituting two known good speakers and maybe you will find your amp is ok. You can temporarily substitute with smaller speakers just to test this.
Dec 12, 2012 | Wurlitzer Jukebox CD Player
My 20 amp fuse for my radio, cd player, and clock keeps blowing?
I had the same problem, with the blowing fuses and all. I solved this by re-routing the wires to a new power source, and of course it should be equiped with a fuse, try that and if not take the car to a mechanic and see if he can find the wire that is live and bare. Normally this happens when a live wire touches gound somewhere on your car can causes the fuse to blow, hope I helped a bit...
Aug 12, 2009 | 2003 Toyota Corolla
Fuel ECU fuse keeps blowing (30 amp)
Your fuel pump is internally binding and causing the fuse to blow. Change the pump (and filter while you're back there.)
Jun 14, 2009 | 1993 Jeep Wrangler
Jandy Aqualink RSO301 keeps blowing fuse
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
May 26, 2009 | Jandy AQUALINK RS TELELINK KIT
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Z-5300 blown fuse
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
Feb 14, 2008 | Logitech Z-5300e Surround Sound System...
Blowing fuses
Here are some answers:
1. Make sure your amp does not have a higher amp rating then the fuse, For example, an 18 amp amplifier will blow an 15 amp fuse, so connect it to a 20 amp fuse
2. you have a connection issue, where something is shorting out
3. you are pushing the amp or car to it's limit with how loud you put it, and thus blowing it, fixed by getting a more powerful amp and a better fuse.
4. or there is something very wrong and cannot help you and you would have to bring it into a shop.
Nov 18, 2007 | Car Audio & Video
96 people viewed this question
 Grubhead
Grubhead
