Question about Canon PIXMA MP600 all-In-One InkJet Printer
Help i cant print
My printer says error code 5100 what do i do?
  • bellacorston Aug 13, 2008
    i have done that chat help surrport but its not working
    Brigadier General:
  • 6,966 Answers
Error code 5100 refers to blockage along the print path. While this could be a number of things, simple remedies may include lubricating the slider rod where the print head moves along. This could be as simple as a drop of oil, cleaning and checking no paper bits or accumulated dust/ dirt or grime. Another area to check is the waste in pad. This would be the white receptacle below the print heads when in park position. On certain instances, the sponge may be dislocated and would simply require moving back in place. At other times, there could be obstruction blocking the print heads resting in the correct park position. This again could be dirt,grime, bits of paper, paperclips, staplers, or even gummed up or dried ink.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
  • Louie  Role
    Louie Role Aug 13, 2008
    Hi again,
    I hope that your printer error was fix with the Live Session.
Gives me a code 5100
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
I can't print my documents. My Printers model is Canon IP2700 and it says there that the error code is 5100. How can I fix the problem? we need the print immediately. Is there any solution we can fix it?
Usually, error code 5100 means some kind of obstruction in the print path, maybe something that had fallen inside the printer, the gears being jammed by something that got loose inside the printer, or ink on the clear plastic encoder/timing strip (a plastic strip about 1/4" in width that you can see running from side to side and connects to the print head).
Clean the plastic strip with alcohol , check if there is nothing blocking the head carriage set (sometimes kids play and hide toys, pens, coins, inside printers, VCRs or any other devices that have "doors"...).
Hope this info may help you!
Mar 12, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
What does error code 5100
For error 5100 try the following, I know it works on some Canon printers:
Unplug printer, press and hold "resume" button, press "power" button and hold down, release "resume", press "resume", release and press again. Release both buttons and now press "resume" 4 times. Power off. Re-start.
Hope this helps
Aug 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error 5100 canon mp470 my screen is showing error code 5100. i cant find the manual to my machine can you help? what exactly does the error mean?
Hi You can Try
Error Code 5100 Seen this many times
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 24, 2009 | Canon PIXMA MP470 All-in-One Printer
I get ERROR 5100 message for my i350 printer...of course it will not print. How is this fixed? Please help.
I had the error code 5100 for my canon pixma ip6220d printer and all it was a pen in the track of the cartridges. I've been looking for that pen for awhile too. So I would say look for something in the way of the cartridges. Hope this helps everyone.
Aug 03, 2008 | Office Equipment & Supplies
Error code 5100
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
Mar 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
186 people viewed this question
old marine
old marine
