Question about HP Office Equipment & Supplies
Have 1300 Series Printer - Paper Jammed and I removed but Display screen still shows Jammed and printer will not print
    Problem Solver:
  • 25 Answers
Have you turned your printer off and on again?
Check to see if there are any small pieces of paper anywhere in
the paper path.
Posted on Aug 13, 2008
Paper jam
Hi Ruth,
This should help you fix the issue.
Remove Jammed Paper
If business card sized paper loaded sideways is jammed:
1. Power the printer off.
2. Open the top cover.
3. Remove the jammed paper with your hands.
Note: Be careful not dirty your hands. Do not use tweezers or other metal instruments to remove the jammed paper or printer damage may occur.
4. Close the top cover and power on the printer
5. Load the papr correctly in portrait orientation to resume printing.
remove foreign objects
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once.
The images below show the iP2200 model.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
Note: Avoid touching inner parts.
4. Power the printer on and confirm that the printer operate normally.
Use a flashlight to find any possible jam.
May 19, 2012 | Canon iP2600 series
Always paper jam on lcd display, even though that the jammed paper was already removed.
If the jammed paper is removed and still show paper jam it means tiny piece of paper is left over in the printer you can use a low pressure vaccum or blower to remove the paper piece before using the blower remove the toner and remove the power plug and the usb connector after cleaning conect the power then the usb then power up printer then in computer click the printer icon in the task bar and remove all the contents then click start settings printer and make your printer default printer right click the default printer and click properties in printer properties click print a test page
Apr 01, 2011 | Canon i-SENSYS MF4120 All-In-One Laser...
The paper had jammed when i was printing, i removed the jammed paper and tried printing again. however, the display on the printer shows paper jammed. what now?
You may have left behind a tiny piece of paper that tore off your sheet as you removed it. Make sure that you have all of the jammed paper and look carefully for any remnants inside. Look to see if the printer did not pick up a second sheet that is still in the system somewhere.
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
Printer will not print after paper jam. after removing the jam the ready light comes on and when we try to print again the screen shows it is preparing to print but it does not print
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 02, 2010 | Minolta magicolor 2400W Laser Printer
Paper jam in hp1300 cannot print
Remove the cartridge and paper tray to see where the paper jam is. If it is a whole page jammed inside of printer, before removing shut off printer and carefully remove paper if you end up tearing a piece this will make it harder to remove in pieces. After you have removed jammed paper reinstall toner cartridge and paper tray turn printer on and see if this clears the jam error message.
May 28, 2010 | HP LaserJet 1300 Printer
Colour printing not working
Hi ,
While printing go to the printer settings nad check if any Black print option is clicked. Also check the color cartridge status.
Jan 26, 2010 | Samsung CLX-3170FN All-In-One Laser...
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
Paper is jammed,but there is no paper in the printer
first... off you printer and then pull the carrier until you reach the carrier of cartridge..and then replace the cartridge..
try to up it again..
May 13, 2009 | Canon PIXMA MP160 All-In-One Printer
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
96 people viewed this question
Ben Johnson
