Question about Xerox Phaser 8560DN Laser Printer
Print smears The first one or two pages come out smeary. I have replaced the maintenance kit with no luck. A response to a similar question about the 8550DN mentioned cleaning the encoder. I took the covers off and saw it. However, how does one get the thing out to clean it or access it otherwise. All help greatly appreciated.
  • elenoa Sep 09, 2008
    Smears on pages from black ink only. I've tried to troubleshoot it using the systems>information>troubleshoot>paper printing quality>eliminate white stripes or eliminate smears...But it doesn't work.. please help
  • jkbahena Mar 02, 2009
    Can someone tell me what the encoder ring looks like so that I can clean it?
    Novelist:
  • 125 Answers
Hi Allan:
Sounds like you need to replace the drum pivot plate assembly. This assembly is what cleans the drum assembly prior to putting the image on the drum. The pivot plate assembly has a rubber drum cleaning blade on it and when the printer begins to print a page it cleans the drum first. If the cleaning blade or the pivot plate are deffective then the drum will not be cleaned properly leaving smudgy areas on the drum.
Posted on Jan 09, 2009
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Hi I am having a problem with our business HP LaserKet 424n printer; when we print anything out it seems to make a noise that it normally doesnt make, and our paper ends up looking smeared to the point ink...
Take print out of configuration page(menu-information-configuration page), chech the maintenance kit interval 2,25,000 crossed?
YES... replace maintenance kit & Swing plate assm..
NO... check fuser sleeve surface arrested with toner?...Replace fuser...
Sep 04, 2011 | HP LaserJet 4240n Printer
Why is my Phaser 8400 leaving black smears on my printed pages and after running remove print smears, it doesn't correct the problem.
Have you looked at the roll in your maintenance kit? It may be dry in that area and not applying enough lubricant on the drum. Or you have some contaminant on the print head wiper blade or the mylar strip in the maintenance kit. Sounds like something is making contact with the drum causing your problem.
Mar 03, 2010 | Xerox Phaser 8400 Laser Printer
Hi jepeto997:
Try these steps.
Check for and remove any media, jammed
paper, or debris found in the printers exit
path.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Clean the maintenance kit wiper blade or
replace the maintenance kit.
Complete. Go to Step 3.
3 1. Check the exit area, exit frame, the
preheater, maintenance kit, and the
printhead (including the paper release blade)
to see if there is anything touching the drum
assembly.
2. Reseat any printer component interfering or
touching the drum assembly.
If there are streaks on the front side only of a
2-sided print, the preheater may be scraping
ink off the print.
2. Look for ink shavings along the streaks on
the printed paper.
3. Clean the preheater using the Control Panel
Remove Print Smears function.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Possible weak or missing jet. Print the weak/
missing jet test print from the Control Panel,
see "Weak/Missing Jet" on page 5-33.
Complete. Go to Step 6.
6 1. Possible discolored jet. Print the solid fill test
print, see "Black, Red, Green, Blue, Cyan,
Magenta, and Yellow Solid Fills" on
page 5-40.
Complete. Go to Step 7.
7 1. The X-axis drive is not functioning correctly.
If the X-Axis Drive does not move the
printhead smoothly and evenly during
printing, vertical lines appear on the print.
For information about X-Axis Drive
problems, see "White Stripes (Pinstripes)"
on page 5-30.
Complete. Go to Step 8.
8 1. Smears on a duplex print can be caused by
the paper preheater operating at a
temperature that is too high or debris is in
the duplex roller or duplex paper path
guides.
2. Run the service diagnostics Duplex Path
test to check the paper preheater’s
temperature.
3. Is the operating temperature within the
correct value range?
guides.
temperature.
Replace the
preheater.
Replace the
electronics
module
Hope this helps
3. Clean the paper release blade.
May 20, 2009 | Xerox Phaser 8560N Laser Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Printer smears on cold print
The toner cartridge sounds like the problem to me. Did you refill it? Or have it done? It sounds like an incompatible brand......toner is very model specific, and not just 'any' will do, and it often doen't mix well with the remaining toner i the cartridge if it is not completely disassembled and cleaned out. Just curious
Mar 16, 2009 | Brother HL 5250DN Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
The ink seems to smear or drag down the page.
What normally causes that condition is a worn or dirty wiper blade. That blade is located between the print head and the drum. Is will not clean properly between prints.
There is a possibility that the maintenance kit could be the problem depending on how it was stored.
That is a roller impregnated with silicon lubricant, if it is stored standing on end, the lubricant will seep to one side and the opposite side will be pretty dry causing smears and streaks.
Also, have you gone into the tools mode and run the cycle to remove smears and smudges? That can help resolve your problem.
With the problem getting somewhat less as you run, I would take a good look at the maintenance kit just to see how it is cleaning. Look at the large roller and see if there are any sopts.
Nov 19, 2008 | Xerox Phaser 8500/DN Printer
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
May 21, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
411 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
