Question about Xerox Phaser 8500/DN Printer
8500 phaser timing
Still have timing problem. Gears grind when starting up.
I have set the module of gears on the right side, holes lined up in gears and lower gear at arrow. Upper gear hole up and a little to left. Head free and wiper down. Gears on left all run free and square block cleaned. Any thing else I need to do? It did pass a page clear through a couple of times. Jams either in front or with page half out of top. Then stops with an error.
Errors I have gotten, 4,024.45:6975......08, 035.42:6975.......08,025.41:6975 in that order.
The maintenance module moves up and down and the drum turns off and on. Could it be a firmware problem? I have reset the Navram from the menu. Thanks for any and all help so far. Steve
  • 1 more comment
  • stevefxxx Aug 13, 2008
    Thanks for your reply.
    What can I do with or about the pressure plate?
    I don't know where, what it is or what it does.
    Steve
    Steve
    Thanks again.
    There was a chunck of cooled off ink under the plate.
    Earlier I found the black ink tray was pushed out of place and could have alowed it to leak.
    Problem fixed.........
    Steve
    President:
  • 2,072 Answers
Doubtful its the firmeware. The maintenance kit pressure plate with sensor is most likely the problem. Once teh process drive is times and aligned properly then the pressure plate is really the only thing left.
Posted on Aug 13, 2008
  • Rick Kasper Aug 13, 2008
    It is the black flat plastic piece under teh maintenance kit that lifts it up and down. Located to the left and below the maintenance kit.
I have a Xerox, Phaser 8650 displaying the following code: 07,010.43:41982
There are alignment motors that rotate the heads do go bad and cause that code recommend a proper service agency look the machine over
Nov 26, 2013 | Xerox Phaser 8500/DN Printer
Gear grinding
Sounds like your Process Drive Assembly has broken its mounting posts and the gears are no longer meshing properly, causing the grinding noise. The drive assy is located on the right side of the machine toward the front. It is held in place with 3 screws. If you wiggle on the gear assy and it moves, then you should go ahead and replace the machine. This is not a do-it-yourself type of repair and should be left to a Xerox Certified Technician if you decide to repair the machine.
Jun 10, 2013 | Xerox Phaser 8550/SDP Color Laser Printer
Xerox Phaser 8560 displays the following error message when connecting the equipment 07,009:42:155474 What is the solution to this problem because the site of xerox found no reference to this error I...
This is out of the service manual. Generally you can just remove the sides and home everything and it will work fine.
Harry
The 7,007.49, 7,008.41, 7009.42, and 7,010.43 errors indicate that the
Printhead was unable to tilt normally on its axis. Possible causes include:
■ The printer was powered off in the middle of a cleaning cycle and the
Wiper Blade has frozen to the Printhead.
■ A Drum Maintenance Camshaft lobe is broken and holding the Drum
Maintenance Kit’s oil roller against the Drum when it should be retracted
to its home position.
■ Process Drive not being aligned correctly.
■ A damaged Printhead Restraint.
■ Ink spilled in the Roll Block preventing proper Printhead motion.
■ Ink or other debris under the Printhead preventing proper motion.
■ The Wiper Assembly not being aligned correctly or ink spilled in the wiper
tracks.
■ The Head Tilt Gear not being homed correctly.
■ The X-Axis Motor nose cone not being installed correctly.
■ The ferrite torrid on the Printhead interface cable has slipped behind the
Printhead causing the Printhead to bind when it tilts backwards.
■ The black plastic shroud on the back of the Printhead is snapped off and
binding the Printhead when it tilts back.
Caution
After servicing the printer, manually set the following assemblies to their
home position before powering on the printer. See Section 6 for
instructions on setting these components to their home positions.
■ Printhead (tilted forward and disengaged from Printhead tilt gear)
■ Head Tilt Gear (disengaged from Process Drive train; arrows on left
frame point to each other)
■ Wiper Assembly (bottom of travel)
■ Process Drive (holes on Transfix Camshaft and Drum Maintenance
Camshaft line up with marks on frame, large gears within assembly
line up with holes in Process Drive housing)
Aug 17, 2010 | Xerox Phaser 8500/DN Printer
Printer error on phaser xerox 8500 08 045 4348752 - can't find what the problem is
This error tells us that the Media Path Motor 807K16050 is bad.
This is usually caused by bad camshafts 008K02160 & 020K14800, so replace those too.
It is medium difficult and takes about 2-3 hours
Whit
Item, Inc.
May 03, 2010 | Xerox Phaser 8500/DN Printer
08,007.41:8472 It's a phaser 8400 i have no idea what to do..What could it be?
Your print head wiper blade is not moving properly.
The clutch that moves the wiper may be failing.
That blade is located between the drum and print head.
Printhead Wiper Alignment: Rotate the left and right idler gears until the Wiper is all the way to the bottom and the gears cannot be rotated further. Rotating the left and right gears together ensures that the wiper stays parallel and does not pop out of the belts. Now rotate the left idler gear a couple of teeth to raise the left side of the wiper to the top. Make sure that the left side of the wiper is a bit higher than the right side. Might have to try this procedure a couple of times, a couple of teeth at a time, to properly align the wiper.
Feb 08, 2010 | Xerox Phaser 8400 Laser Printer
Got an error code - Xerox Phaser 8500 - error 07.007,40
Hi Mathew392:
Here is your problem.
7,007.49: The process motor stalled while tilting the head.
Step Questions and Actions Yes No
1 1.
Check the printhead wiring for proper
routing.
2. Remove the printhead and inspect the
printhead tilt and drive gears for ink spills.
3. Re-route the wiring.
4. Clean around the gears and printhead.
5. Did this correct the problem?
Complete. Go to Step 2.
2 1. To ensure the gears are correctly aligned,
2. Did this correct the problem?
Replace the process gearbox.
The process gear box is located on the right hand side
of the printer, you will have to remove the right side pannel to access
the gear box to see if the gears in the gear box are aligned. Let me know
if you need aditional information.
pdouglasss@hotmail.com
Dec 14, 2009 | Xerox Phaser 8500/DN Printer
Hp laserjet 3330 gears on right side grinding after print
The most common problem with grinding is from compacted toner. Try changing the toner cartridge.
Aug 26, 2009 | Office Equipment & Supplies
Printer error 07,010.43:722 on phaser 8560 xerox printer
Hi eduardo580:
This your problem.
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
1 1.
Reboot the printer.
2. Did this correct the problem? Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
center position? You should be able to
manually push the printhead right to left.
Clean the printhead area. Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot the X-axis drive.
5 1. Check the process gearbox for obstructions or damaged.
2. Ensure the gears are correctly aligned and homed.
3. Verify the process shaft and drive module shaft are at their home positions.
4. Did this correct the problem? Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the gears. Go to Step 7.
7 1. Use service diagnostics to run the Head Maintenance Wiper Clutch test.
2. Did the test fail?
Replace the wiper drive clutch. Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper Drive Test.
3. Did the test fail?
Replace the exit module assembly. Go to Step 9.
9 1. Use service diagnostics to run the Load Maintenance Clutch test.
Inspect the maintenance drive system,
replace any defective parts. Go to step 10.
10 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
2. Is the gear engaged properly?
Go to Step 11. Set the headtilt gear.
11 1. Use service diagnostics to run the Tilt Axis Drive test.
Go to Step12.
12 1. Use service diagnostics to run the Process Motor test.
2. Did the test fail? Replace the process motor.
Hope this helps
Jul 25, 2009 | Xerox Phaser 8500/DN Printer
Service needed 37,004.40:3157
This error indicates the printer is not in its home position. To reslove you need to open the right side cover and near the mid top you will see 2 gears that is to the print head wiper make sure the print head wiper is all the way down. also make sure the print head is tilted back. Also there is a set of gears near the front and on the bigger gears there are holes line the holes up with the holes on the plastic the cases it.
Thank you
John C
Mar 03, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8500n 70,010.43
A little bit of ink in that area can be normal. Although I would clean it out if I were in there.
To remove the print head, you have to remove that block. Then on each side of the print head there is a plastic bracket held in with one screw on each side. They are brass torx screws, they just lift out of the frame on each side of the print head, they are the print head latches.
You mention the head tilts backrward fine, but don't mention it moving forward. Does it get within about 1/4 of an inch of the drum? Is shoul dmove frely forward also. But removing it may be find the problem.
Remove the loose ink.
One other thing to check is the process drive motor. It is mounted on the right side of the machine and has a gear cluster on it. On the clear plastic are timing holes to ling up the gears to the frame. You can just pin them with paper clips. You have to remove the motor to do that correctly, 4 screws and some connectors run across the assembly. Remove it and pin the gears through the holes and when installing make sure the arrow on the frams lines up with the one on the assembly.
Aug 01, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
325 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
