Question about LG DLE2514 Electric Dryer
Drum noise I have the same noise except mine never goes away and now the drum has cracked right were it rides on the front rollers.
  • 4 more comments
  • carmenlh Oct 11, 2008
    the Drum cracked. I had a loud knocking noise before that happened.
  • lostinNH Nov 10, 2008
    DLE2512W Electric Dryer had 1.5 ears..out of warranty. Loud noises for a day or two..now, turns on for about 6 seconds, then off. Sometimes, it changes it's time left, then starts again..for about 3 seconds. Took apart vent, ran fish line up to front to see if anything in vent..nothing. Of course nothing from dryer to outside vent either. Cooling light always on, drying light blinks..any ideas? How to run diagnostics would be a good start? Called LG and they said it was a venting issue..nothing seems wrong with venting..help?
  • Anonymous Jan 09, 2009
    drum turns for about 6 seconds each time it spins.it seems like drum is out of balance.
  • wonderwom318 Feb 14, 2009
    We have the same problem- clunking craked drum where it is on the rollers- out of warranty and cant find a replacement part- LG customer service no help out of warranty- had for 1.5 years. ANyone know where to get new parts???
  • Anonymous Mar 25, 2009
    My dryer also has cracked. Sears has the parts. They gave me an estimate of 85 dollars not including installation fees.
  • gbkane40 Apr 02, 2009
    You can order a new drum and install it yourself from www.MCMelectronics.com
    I think that mine cast me about $150.00 for the drum about 4 months ago.
  • 5 Answers
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 07, 2014 | Dryers
Drum Noise and not drying proerly
a dryer drum usually rides on rollers. when center of roller wears out then they start to get noisy
Dec 21, 2013 | Zanussi Dryers
Dryer is heating but drum making very loud noise like scraping against something
next time send model number,check the glides on the front bulkhead that the drum rides on,also check the pulley and rollers while your in there and check the blower wheel,make sure it isn't cracked or loose scraping against the housing
Jan 31, 2010 | Amana Dryers
My dryer makes squeaking noise just on the begining of circle.After few minutes it stops.What that could be?
there are rollers that the drum rides on that could be doing this,or the pulley that the belt attaches to,some dryers have glides on the front bulkhead or like frigidaire the drum rides on a back bearing that wears down,one more thing to check is the blower wheel,next time send brand name and model number,take out the drum and move the rollers and pulley by hand or try rotating the drum by hand to see if you hear the noise,see if it's in the front or back of drum and go from there
Dec 05, 2009 | Frigidaire FSE748GF Dryer
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Electrolux FGX831FS1 dryer drum, only spins one way manually
Check inside the drum to make sure the three screws in a triangle in the rear center are all there, if they fall out the drum goes off center and the motor can no longer drive it.
This model has no rollers, the front of the drum has plastic glides mounted on the front of the drum that ride on teflon impregnated pads that are glued around the door.
The rear is supported by a steel ball screwed to the rear of the drum (the 3 screws that I think are causing your troubles) that rides in a plastic saddle screwed to the rear of the machine.
If the excess drum movement is only up and down you should replace the front glide system.
Good Luck
Quentin
Apr 26, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud Thump each time the Drum Rotates
A new drum and rollers should have solved this issue. The rollers were upgraded to have a harder rubber consistency about 1 year ago. Ensure that the technician did not use old stock parts. The new, updated rollers should have a blue dot on them. As for a cracked drum weld, this would be a defective part. Make sure to call LG customer service to have the issue documented so that there will be a history. This way, even when your unit goes out of warranty they will have records of the service and the repairs should still be covered for sometime.
Nov 23, 2008 | LG DLE5977 Electric Dryer
Loud dryer
You can fix this yourself if you haven,t used it long like this. THis is caused by the rollers that support the back of the drum coming wearing out in the middle. this causes them to wobble and drop down. Then the rear top of the drum rides on the metal back which well eventually wear a hole in it.
UNPLUG THE DRYER
1 Take out the lint filter on top and remove the 2 screws there.
2. Use a thin bladeed screwdriver or butter knife to push in the crack right under front top. THere is a clip on each side that has to be pushed in to be able to lift up the top
3. disconnect the wires to the door switch. 2 wires if no drum light 3 if there is a light. If only 2 wires it doesn't matter where they go. If more mark them so you get them back right.
Most gas dryers have a separate bottom panel that just swings down from the top. You may need to pry with a screw driver. Remove this first.
Electric dryers and some newer gas dryers have a solid front panel.
When you lift the top of the dryer prop it up and out of the way. There will be a screw on each side holding the front panel on. It takes a 1/4 inch socket to remove. A solid panel dryer will have clips holding the bottom on. Just pull the top out and away from the drum and lift up. It should come free. If there is a separate bottom panel, loosen but dont remove the screws. This will let you remove the front panel. The drum will drop down. and act like it will fall out, the belt will hold it.
Look under the dryer and pay close attention to how the belt is run. THere is a springy idler pulley It is just held by aslot in the bottom. It will probably fall out when the belt is gone. Pull it back and release the belt. Take out the drum. There will be at least 2 roller wheels supporting the drum in back. These need to be replaced. Possibly the shaft as well. Most of the time just the rollers are worn out in the middle and wobble on the shaft. I always replace the rollers, the belt and the idle pulley. Check the felt seal on the back side of the drum If its damaged replace it. Check the nylon strip that the front rides on. again replace it if needed. Most of the time you just need , belt, rollers and idle pulley They shouldn't cost more than $20 - $35 for all. The main reason for a new belt is that the new belt has a diagram of how to install it. First time is rough. THis shouldn't take more than an hour to do and you really can do it yourself. If you get stuck look in the library for a book with pictures. Most Whirlpool, Kenmore and Roper dryers are all the same. The rollers, and pulley are generic to almost all models. There are only about 3 - 5 different belts
Jun 28, 2008 | Kenmore Dryers
Noisy drier
I had the same problem with my dryer. The large cloths drum rides on two wheel bearing rollers that are mounted behind the drum. If one of those bearings to the rollers wears out, it will make a loud racket. If you want to repair it your self, purchase a repair manual for your model dryer. Then Disessemble the front of the dryer to expose the large drum. Remove the belt that goes around the drum. Then remove the drum. You will then be able to see the two rollers that the drum rides on. Go to your nearest parts store and replace both of them. Good luck.
Oct 02, 2007 | Dryers
LG DLE2514 Electric Dryer Logo
275 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
