Question about Dell 1600n All-In-One Laser Printer
Dell Printer 1600n
The printer messasge center is saying 'no paper, add paper', however there is paper in the tray and the machine does not have a paper jam. Machine is not recognizing that there is paper in the tray.
  • aquariusfire Sep 17, 2008
    I have the same problem and I don't have a manual. What and where is the manual feed tray?
Check your manual feed tray. The printer may have a print job in memory that's pointing there.
Posted on Aug 14, 2008
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
It say error JAM 1 what does that mean
Look inside printer to see af any paper is in there if so remove.Pull out paper tray and clean pickup roller (roller that picks up paper from tray)if the roller has film on it it will cause jam1 error
Mar 22, 2010 | Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
My printer says I need paper. It has paper. Will not print or copy
Try to update the Firmware, or check the sensor of the feeder could be out of place and doesenot recognize the paper.
Jun 17, 2009 | Dell 1600n All-In-One Laser Printer
Hi. I've a Dell 1600n printer. There is plenty of paper in the drawer, but message says No Paper/Add Paper.
Remove the drawer then insert again.. if the same problem.. clean the sensor maybe its broken.
Jun 15, 2009 | Dell 1600n All-In-One Laser Printer
Printer will not print. Displays no paper.
Is the page stop at the back of the tray set correctly? If you have the stop a "click" off, rather then seeing letter size, it will see universal or A4 and say no paper, because it's looking for letter size. If it is on the network, just open a browser and go to the IP address of the printer, or print out a configuration report. That will tell you what size the drawer is reading.
Jun 16, 2008 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n printer
Not sure what you mean. Can you describe the "separation pad" color, size, apparent feature, please...
Mar 05, 2008 | Dell 1600n All-In-One Laser Printer
Add paper message
you will be glad to know, this is not your printer's fault. We went round and round with dell support when we first got 150 dell 1600n's. We sent in copies of documents that were causing the problem. Finally, they figured it out for us. Embedded in the document was junk that was telling the printer to pull from tray2. All you have to do to fix the problem, is take the word document, go into file, page setup. on paper tab, select default tray for first page, default tray for all other pages, and apply to whole document. to clear the message, you will have to delete the print job from the queue, and turn off the printer, then turn back on, and you should be set. The message add paper, is really what the printer should be telling you, except that it should add to tray2, so you know it is trying to pull paper from the manual sheetfeed port on the front.(you could add paper there, till the document finishes printing, but our docs are hundreds of pages, so that is not practical. Barry Smoke Network Administrator AR Division of Legislative Audit
Feb 25, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
204 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
