C++ program a program to find the binomial coefficient using simle method
Posted on Aug 13, 2008
SOURCE:
How to do binomial coefficients
In run scree, press the OPTN key, Press F6>. In the next page press F3Prob. The combination tab is above the F3 key
Jul 18, 2014 | Casio Office Equipment & Supplies
Umax astra 1600u driver
try install program Simple Scan I use linux mint 17 lxde and my epson perfection 1650 work automaticly with Simle Scan Linux is unix program as Mac OSX i hope it will work too.
Jul 17, 2014 | Office Equipment & Supplies
Demonstrate how to multiply two binomials
Try to seek these: By using the suggested format:
Suggested su
  1. Adding and Subtracting Binomials
    • 1
      Arrange each term in each binomial in order of degree from greatest to least. The degree of a binomial is the exponent attached to the term. For example, 4x^2 is a second degree term.
    • 2
      Multiply each term in the binomial that is being subtracted by -1 to turn it into an addition problem. For example, the problem (8x^2 + 8) - (x^2 - 2) becomes (8x^2 + 8) + (-x^2 + 2).
    • 3
      Combine like terms. In the example problem, the x^2 terms are combined and the constant terms are combined, yielding (8x^2 + 8) + (-x^2 + 2) = 7x^2 + 10.
    Multiplying Binomials
    • 4
      Understand the F.O.I.L. method. F.O.I.L. is an acronym standing for first, outside, inside and last. It means that you multiply the first number of the first binomial by the first number of the second, then the numbers on the outside (the first term of the first binomial by the second term of the second binomial) and so on. This ensures that both numbers in the first binomial are multiplied by both numbers in the second.
    • 5
      Use the F.O.I.L. method to multiply the two binomials together. For example, (3x + 4)(3x - 4) = 9x^2 +12x - 12x - 16. Notice that -12x is the product of the outside terms and -16 is the product of the last terms, 4 and -4.
    • 6
      Simplify. There will almost always be like terms to combine. In the example, 12x and -12x cancel out, yielding the answer 9x^2 - 16.
    Dividing Binomials
    • 7
      Use the distributive property to divide both terms in the binomial by the monomial divisor. For example, (18x^3 + 9x^2) / 3x = (18x^3 / 3x) + (9x^2 / 3x).
    • 8
      Understand how to divide by a term. If you are dividing a higher order term by a lower order term, you subtract the exponent. For example, y^3/y = y^2. The number part of each term is handled like any other division problem. For example, 20z / 4 = 5z.
    • 9
      Divide each term in the binomial by the divisor; (18x^3 / 3x) + (9x^2 / 3x) = 6x^2 + 3x.
May 10, 2014 | Computers & Internet
Texas 30XIIB binomial cdf
The only known equation for the cumulative binomial distribution is the sum of the individual binomial probabilities. Some more sophisticated (and more expensive) calculators have that equation built in, but the 30xii does not.
If n>30 and n*p>5 and n*(1-p)>5 then you can approximate the cumulative binomial with the normal probability function, but again the 30xii does not have that built in.
Apr 14, 2014 | Texas Instruments TI-30 XIIS Calculator
(3n+2)(n+3)
To multiply binomials use the mnemonic FOIL
  1. Multiply the FIRST members of the two binomials: 3n*n=3n^2
  2. Multiply the OUTER members of expression when read from left (3n) to right (3) =9n
  3. Multiply the INNER members 2 *n=2n
  4. Multiply the LAST members of the binomials 2*3=6
  5. Add all the products 3n^2+ 9n+2n+6,
then combine the two like-terms 9n+2n=11n
Result is 3n^2+11n+6
Seriously now: what does this have to do with Printers and Copiers?
Sep 21, 2013 | Office Equipment & Supplies
Definition of special product in algebra types and example of special product in algebra
Product means the result you get after multiplying.
In Algebra xy means x multiplied by y
Likewise when you see (a+b)(a-b) it means (a+b) multiplied by (a-b), which we will be using a lot here!
Special Binomial Products So when you multiply binomials you get ... Binomial Products
And we are going to look at three special cases of multiplying binomials ... so they are Special Binomial Products.
1. Multiplying a Binomial by Itself What happens when you square a binomial (in other words, multiply it by itself) .. ?
(a+b)2 = (a+b)(a+b) = ... ?
The result:
(a+b)2 = a2 + 2ab + b2
You can easily see why it works, in this diagram:
2. Subtract Times Subtract And what happens if you square a binomial with a minus inside?
(a-b)2 = (a-b)(a-b) = ... ?
The result:
(a-b)2 = a2 - 2ab + b2
3. Add Times Subtract And then there is one more special case... what if you multiply (a+b) by (a-b) ?
(a+b)(a-b) = ... ?
The result:
(a+b)(a-b) = a2 - b2
That was interesting! It ended up very simple.
And it is called the "difference of two squares" (the two squares are a2 and b2).
This illustration may help you see why it works:
apb-amb-why.gif a2 - b2 is equal to (a+b)(a-b) Note: it does not matter if (a-b) comes first:
(a-b)(a+b) = a2 - b2
The Three Cases Here are the three results we just got:
(a+b)2 = a2 + 2ab + b2 } (the "perfect square trinomials") (a-b)2 = a2 - 2ab + b2 (a+b)(a-b) = a2 - b2 (the "difference of squares") Remember those patterns, they will save you time and help you solve many algebra puzzles.
Using Them So far we have just used "a" and "b", but they could be anything.
Example: (y+1)2
We can use the (a+b)2 case where "a" is y, and "b" is 1:
(y+1)2 = (y)2 + 2(y)(1) + (1)2 = y2 + 2y + 1
Example: (3x-4)2
We can use the (a-b)2 case where "a" is 3x, and "b" is 4:
(3x-4)2 = (3x)2 - 2(3x)(4) + (4)2 = 9x2 - 24x + 16
Example: (4y+2)(4y-2)
We know that the result will be the difference of two squares, because:
so:
(4y+2)(4y-2) = (4y)2 - (2)2 = 16y2 - 4
Sometimes you can recognize the pattern of the answer:
Example: can you work out which binomials to multiply to get 4x2 - 9
Hmmm... is that the difference of two squares?
Yes! 4x2 is (2x)2, and 9 is (3)2, so we have:
4x2 - 9 = (2x)2 - (3)2
And that can be produced by the difference of squares formula:
Like this ("a" is 2x, and "b" is 3):
(2x+3)(2x-3) = (2x)2 - (3)2 = 4x2 - 9
So the answer is that you can multiply (2x+3) and (2x-3) to get 4x2 - 9
Jul 26, 2011 | Computers & Internet
How to solve foil method
The FOIL Method is a process used in algebra to multiply two binomials. The lesson on the Distributive Property, explained how to multiply a monomial or a single term such as 7 by a binomial such as (4 + 9x).
1.gif But, what if there was a binomial instead of a single term outside of the parentheses? That is, what if a binomial was being multiplied by another binomial? An example of this is given below.
FOIL stands for:
First - Multiply the first term in each set of parentheses Outer - Multiply the outer term in each set of parentheses Inner - Multiply the inner term in each set of parentheses Last - Multiply the last term in each set of parentheses Now let's give it a try in our problem. We'll start by multiplying the first term in each set of parentheses and then marking down the answer below the problem.
3.gif Now we will multiply the outer terms and again mark down the answer below the problem.
4.gif And the Inners.
5.gif And finally the last terms.
Jun 12, 2011 | Computers & Internet
TI-89 Titanium: I want to solve a Binomial Theorem problem (x+y)^6 how would i go about solving this in the calculator?
Using elementary algebria in the binomial theorem, I expanded the power (x + y)^n into a sum involving terms in the form a x^b y^c. The coefficient of each term is a positive integer, and the sum of the exponents of x and y in each term is n. This is known as binomial coefficients and are none other than combinatorial numbers.
Combinatorial interpretation:
Using binomial coefficient (n over k) allowed me to choose k elements from an n-element set. This you will see in my calculations on my Ti 89. This also allowed me to use (x+y)^n to rewrite as a product. Then I was able to combine like terms to solve for the solution as shown below.
(x+y)^6= (x+y)(x+y)(x+y)(x+y)(x+y)(x+y) = x^6+6x^5y+15x^4y^2+20x^3y^3+15x^2y^4+6xy^5+y^6
This also follows Newton's generalized binomial theorem:
Now to solve using the Ti 89.
Using sigma notation, and factorials for the combinatorial numbers, here is the binomial theorem:
The summation sign is the general term. Each term in the sum will look like that as you will see on my calculator display. Tthe first term having k = 0; then k = 1, k = 2, and so on, up to k = n.
Notice that the sum of the exponents (n ? k) + k, always equals n.
The summation being preformed on the Ti 89. The actual summation was preformed earlier. I just wanted to show the symbolic value of (n) in both calculations. All I need to do is drop the summation sign to the actual calculation and, fill in the term value (k), for each binomial coefficient.
This is the zero th term. x^6, when k=0. Notice how easy the calculations will be. All I'm doing is adding 1 to the value of k.
This is the first term or, first coefficient 6*x^5*y, when k=1.
Solution so far = x^6+6*x^5*y
This is the 2nd term or, 2nd coefficient 15*x^4*y^2, when k=2.
Solution so far = x^6+6*x^5*y+15*x^4*y^2
This is the 3rd term or, 3rd coefficient 20*x^3*y^3, when k=3.
Solution so far = x^6+6*x^5*y+15*x^4*y^2+20*x^3*y^3
This is the 4th term or, 4th coefficient 15*x^2*y^4, when k=4.
Solution so far = x^6+6*x^5*y+15*x^4*y^2+20*x^3*y^3+15*x^2*y^4
This is the 5th term or, 5th coefficient 6*x*y^5, when k=5.
Solution so far = x^6+6*x^5*y+15*x^4*y^2+20*x^3*y^3+15*x^2*y^4+6*x*y^5
This is the 6th term or, 6th coefficient y^6, when k=6.
Solution so far = x^6+6*x^5*y+15*x^4*y^2+20*x^3*y^3+15*x^2*y^4+6*x*y^5+y^6
Putting the coefficients together was equal or, the same as for when I used the expand command on the Ti 89.
binomial coefficient (n over k) for (x+y)^6
Jan 04, 2011 | Texas Instruments TI-89 Calculator
NCr + nCr-1 = n+1Cr prove it?
The identity (n+1)Cr=nCr+nC(r-1), valid if n>=1 and 1=0. These facts embody the construction of Pascal's triangle and let you prove by induction (on n) that nCr is always an integer since it's either 1 or it's the sum of two integers.
You can also think of the combinatorial definition of nCr, the number of r-subsets of an n-set. This is definitely an integer. Of course then you'd have to prove that the factorial expression for nCr is correct...
The nCr are binomial coefficients with the property that n+1Cr = nCr-1 + nCr (think of Pascal's Triangle) with nCn = 1 = nC0. Since 0C0 = 1 it follows that all nCr are integers
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 06, 2010 | Dell Computers & Internet
I was told that, to do binomial distributions on a ti-86, I would need to hit 2nd Math, then More, and I should see something that says STAT and go from there to get to DIST and Binomi. I see nothing...
Sorry, but you information is wrong, to find the binomial distribution use the PROB menu not the STAT menu. Its name is randBi
[2nd][MATH][F2:PROB] scroll right.
Hope it helps.
Oct 10, 2009 | Texas Instruments TI-86 Calculator
Open Questions:
\Q;- HP customer care phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This HP USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 HP USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the HP USA customer care department for problems like Where to buy, Complaint, customer care, Repairs, Returns. As far as we can tell, HP USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact HP USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP USA Calling HP USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our care call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP USA customer care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP USA's customer care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP USA's phone numbers against each other. Contacting HP USA in General While [+I8OO-8O3-1O69] is HP USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach HP USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP USA.
Oct 18, 2019 | HP Computers & Internet
\Q;- KYOCERA customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KYOCERA USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KYOCERA USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the KYOCERA USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, KYOCERA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KYOCERA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KYOCERA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KYOCERA USA Calling KYOCERA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KYOCERA USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KYOCERA USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KYOCERA USA's phone numbers against each other. Contacting KYOCERA USA in General While [+I8OO-8O3-1O69] is KYOCERA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach KYOCERA USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KYOCERA USA.
Oct 18, 2019 | Kyocera Computers & Internet
Computers & Internet Logo
43 people viewed this question
Ekse
Alun Cox
