Question about Mintek Televison & Video
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
  • Lou Warneke Aug 13, 2008
    Ihave a portable dvd player model number mdp1030 it keeps saying it has no disc I tried cleaning with a dvd cleaner but it did not help. any suggestions?
    Master:
  • 623 Answers
Dvd lens burnt buy new portable player
Posted on Aug 13, 2008
  • Anonymous Aug 13, 2008
    never touch lens
    no hope for player
  • 4,234 Answers
Thios message indicates that the unit could not read the disc. The first thing to try is to gently clean the lens using a cotton swab and alcohol. If that failes to resolve the problem, try playing a music CD. If the music CD plays, the optics are starting to fail. DVDs require more power to read than CDs.
Dan
  • 2,337 Answers
It appears like the laser pick up Assembly is not longer reading the info from the DVDs.
I would suggest to use a lens cleaner to see if you can restore the DVD player functionality.
If the lens cleaner did not work, the lens or laser pick up is defective. This type of repair might cost you more then buying a new DVD player.
    Guru:
  • 1,894 Answers
Then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
SOURCE:
Wont read dvds and says that theres no disk inside when there is one inside
Hello i have three portable dvd players and after a while they all done the same thing they all say no disk when disk is inserted. I have try'd different disk but keeps coming up no disk can you help please advise
thank you
Jan 09, 2011 | Venturer PVS177W Portable DVD Player
Portable dvd player broken
You can get a cdrom cleaner kit and try that which may work. If that doesn't work you're stuck replacing it as the repair would cost more than the unit.
Aug 07, 2009 | Insignia IS-PDO40922 Portable DVD Player
Says no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Jan 31, 2009 | Mintek MDP-1815 Portable DVD Player
Portable DVD player .disc error unit spins but says says no disk
Likely to be a classic laser failure. It will require technical person to replace it - try starting with the point of sale and see about warranty etc
Dec 17, 2008 | Televison & Video
My coby portable dvd player keeps telling me that I have invalid
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Thanks for using FixYa.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call the number above for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 01, 2008 | Coby TFDVD5000 Portable DVD Player
My coby portable dvd player keeps saying wrong disc
You may need to clean the laser in the unit. You can purchase a cleaning disk at Radio Shack or Best Buy. They are normally less than $20.
Nov 06, 2008 | Coby TF-DVD7107 Portable DVD Player
DVD Player that repeatedly says "no disk" when there is a disk in it
Same here. I've tried placing the DVD in a vertical position just to start and sometimes it works.
Dec 22, 2007 | Polaroid PDM-0742 Portable DVD Player
Dvd
ribbon cable issue found with this device. look inside at the white ribbon cable. The cable likes to bunch in bewtween the spinning hub and the eye assembly, after time it may even develope a rub spot that will shut you down for good. If the cable is bunched up, try pushing it back into the bottom of the device and try again.
Nov 15, 2007 | Durabrand PDV-705 Portable DVD Player
Televison & Video Logo
138 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Ekse
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
