Question about HP Computers & Internet
I have a hp pavillion f1723 but it wont switch on, the green led power light keeps flashing, what does this mean?
  • 477 Answers
Count the times the green led flashes? and how it flashes that´s an error code for your problem. it can be the motherboard or power.
Posted on Aug 13, 2008
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
May 05, 2017 | HP Computers & Internet
How do i repair green blinking light in motherboard and not powering up?
Why would you want to try to repair a working green LED?
But you need a manual, to check what the blinking light means. See how it flashes, because the board is trying to tell you what is wrong with these flashes. Like perhaps bad voltage, or bad RAM or ROM? or lost all settings.
Feb 12, 2015 | HP Compaq d530 SFF PC Desktop
Hp pavillion lighitng bolt led on front keeps flashing and will not power on
I see that you said that you "powering on the AC adapter only".
Does that mean you tried booting with the battery removed?
If not, completely remove the battery and try to boot.
If that fails too, it will be a switch or board issue
Mar 12, 2013 | Computers & Internet
Dc 5000 sff. wont power up. green light on motherbd flashes. if power on button is pushed, the front green led blinks too. I have replaced the pwr supply w/no change.
make sure both the 4 pin and 20 pin connectors are firmly installed. if the mobo light flashes how many times does it flash, do you hear any beeps?
May 10, 2012 | HP Compaq dc5000 PC Desktop
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
Jun 15, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Power led on hp monitor flashing
mham2525, Did it have a "perfect" picture on it yesterday? You do know that if the COLD-CATHODE-FLUORESCENT-TUBES that are hung on the rear of the LCD PANEL fail to light, all you get is a BLACK screen to look at!!!!! OMG, What shall I do now???? It sure would be nice if all we needed to do was remove the cover and then screw-in 4 new CFL light bulbs into our monitors. YOUR UNIT WILL NEED TO BE TROUBLESHOOTED AND REPAIRED. MOST LIKELY A SMPS/INVERTER BOARD FAILURE. CALL HP TO SEE IF THEY HAVE A SWAPOUT PROGRAM. Bye for now. lmistyrel @aol.com
Sep 24, 2009 | HP Pavilion F1703 17" LCD Monitor
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps...
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Jan 06, 2009 | HP Media Center m1180n PC Desktop
Power led flashing...
The described problem might not be the Power Supply Unit, there are a number of different reasons that may cause this symptom. Consulting HP would be advisable.
Jan 30, 2006 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Computers & Internet Logo
312 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
