SOURCE: Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
SOURCE: Ricoh FAX5000L - Check: Network Error! [10-40]
Usually this means it was previous;y hooked up to a network, or the network settings have changed and they are mismatched. Do you use it as a printer? If not, in the user settings, (I'm not exactly sure where, but you can download a manual at ricoh.com) just set all the network settings to 0's - for example Ip address, gateway, etc. Otherwise set them correctly in order to print.
SOURCE: Ricoh Fax 3700L
Fuser error.....Either blown fuse, bad thermistor, or blown lamp. Problem needs to be repaired, and then a WAY over complicated reset procedure has to be performed in service mode to clear the error.
SOURCE: Ricoh 5510L Network Setup
Go to user tools-key op tools-network-tcp ip- ip address put the appropiate info in.(including gateway address.) then type the ip address into the top portion of a web browser an you should be in web image monitor. you configure the printer there. User name is admin no password. -Carl
Savin 3750nf is not sending emails. I can access the machine from my computer to see that it is not sending scanned jobs and that all of the network settings appear to be correct. It just won't send emails.
