Question about Refrigerators
My sunbeam wine refrigerator is icing up on the inside back wall. I defrost it, plug it back in and it is icing up right away.
  • tangelakos Sep 26, 2008
    Same problem here. Only started doing this since we moved to Florida, two years ago. I thought it might be due to the high humidity in Florida, but new info suggested the rubber magnetic seals, around the door frame, may not be making a tight seal - letting hunidity enter. Also, the drain, in the back and at the bottom of the interior, leads to the collection tray. This is open to the atmosphere, so humidity could be getting in through that hole, too. Since I never had any water collecting in the tray before moving to Florida, I am going to plug up the hole. I'll also repair any areas along the door seals that don't function properly.
5 Suggested Answers
SOURCE: Water leaking inside refrigerator
Its the clogged defrost drain. I have the same problem. I just cant find the drain
Posted on Jun 07, 2008
  • 71 Answers
SOURCE: Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Posted on Dec 25, 2008
  • 286 Answers
SOURCE: u-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Posted on Jun 15, 2009
woodchuck789
  • 4059 Answers
SOURCE: About every 2 months the defrost drain gets plugged
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jul 01, 2009
woodchuck789
  • 4059 Answers
SOURCE: Refrigerator freezer drains keeps freezing over, not plugged.
Posted on Jul 02, 2009
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
What causes Ice build up on inside back panel of kitchenAide KUWA244PBS?
normally that means yhe defrost thermstat is bad or the heating element that causes the defrost is bad.
Aug 31, 2014 | KitchenAid KUWA244PBS Wine Cooler
Refrigeartor not chilling, freezer not freezing
If you have built up ice inside the freezer walls, and the defrost assembly isn't functioning, this could be the problem.
Defrost the unit! Take all the food out of the freezer side, remove shelves; remove inside back panel. If there is a lot of ice build up there, then your defrost assembly is not working or your refrigerator is not a frost free unit. Defrost either by leaving the freezer door open over night or you can speed the process up with a hair dryer. Once the ice build up is dealt with, you can plug the refrigerator back in and see if it will now freeze the freezer and chill the refrigerator. If it does, and you have a defrost assembly you need to order it and have it on hand when the ice builds up again.
Jun 05, 2011 | Refrigerators
My wine coller won't hold the temperature set
If it IS a small compact refrigerator, used as a wine cooler, then it may be "iced up" and just need defrosting, if only part of the coil is iced, it is probably low on gas, or the "condenser" coil on the back (or under) the unit may be dirty, a fan not running, or just too close to a wall and not breathing). It is "doubtful that the thermostat is bad, but just setting it colder will tell, and the "setting" is usually marginal anyway.
If it's a larger unit with a fan or fans inside Like a walk-in cooler, then there are other possibilities
May 12, 2011 | Refrigerators
Mattag PSB 2151 Side by Side Fridge/Freezer. Water is dripping out at front corner under freezer side everyday. Defrost Thermostat?
Most likely plugged up defrost drain hole. Do you see any frozen water (ice) in bottom of freezer? If so then remove lower back wall of freezer compartment and use a turkey baster with some hot water to "plunge" the defrost drain tube till the water starts to flow. Clean up excess ice and away you go!!
Jun 14, 2010 | Maytag PSB2151G Side by Side Refrigerator
Interior icing of back wall of wine cooler, Sears (Kenmore) model 461.99609, stand alone wine cooler
as this is not self defrosting you have to do it yourself..........warm air causes frost buildup!
Jun 12, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Thick ice is building up on the inside back wall, i'm
not defrosting it totally, unplug unit and use a blowdryer to defrost the return air ducts, they are located behind the panel on the rear wall of the freezer
Oct 28, 2009 | AEG S72348KA ST STEEL Refrigerator
Not keeping food cold and popping noise
There is ice buildup in an area that you cannot see.
The interior wall may "bulge" a little if the ice builds up a lot.
1. You may have the cooling dial set too high (use lower numbers)
2. The blower vent into the fridge or freezer maybe blocked (move items away from vents inside)
3. Defrost the fridge. The water pan underneath the refrigerator may overflow.
If there is no "defrost" setting, unplug for an hour (don't open refrigerator or freezer during defrost)
Plug back in, food will not spoil.
Sep 21, 2009 | Haier Refrigerators
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
