It can be difficult to fix a leak without the proper tools. Hopefully the leak will be in a flare nut that can be tightened, or sometimes repairmen will forget to tighten the service port nuts. The service ports are where the copper lines connect to your outdoor unit and service guages would connect as well.
You can try to make you some real soapy water solution in a bowl. Take a little paint brush and brush it on to every connection you can find on the copper lines. You can buy a small container of soap bubbles at a plumbing or air cond supply house. In order to weld a leak though, you will have to relieve all refrigerant out of the unit and use a torch, then re evacuate the unit and charge it back up. This would take a repair man. Good luck
THanks! Last year my unit was empty of freon and we had it refilled, hoping it wasn't really aproblem. At that time the service guy told me that it was pointless to try to find the leak because 99% of the time it was in the condensor which always rusts b/c of the water collection. It would be cheaper to replace than to repair. Thanks for the info.
