Question about Dell Inspiron E1505 Notebook
Data encryption how do i enable encryption on my laptop? now it says encryption - disabled. Anna
    Genius:
  • 2,028 Answers
You should be able to enable the encryption from the bios at start up.
Posted on Aug 13, 2008
Help with my rca decrypt storage password i am locked out
No password, no data and no more use to anyone. There are companies who will decrypt it for you but all your data will be lost.
Feb 08, 2016 | Computers & Internet
Hi my son has a acer one aspire and it will not detect wireless ney works. the wan switch works to say wan lan disabled and enabled acordingly i have reinstalled the drivers but all to no avale it is...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Aug 22, 2011 | Acer Aspire One PC Notebook
I put in the wireless router and I'm able to access from my computer but I my laptop can't locate. What do I need to do?
Jun 29, 2011 | Linksys Wireless-G WRT54GS Router...
How do I disable microsoft bit locker from the start buttom bottom left of desktop page, everytime i turn on the computer i've to statr about -10 times before it will start, i hit the home button which i...
Copy and paste the following link into your internet browser:
http://www.techtalkz.com/windows-7/515981-enable-disable-bitlocker-drive-encryption-windows-7-a.html
This is for Windows 7 OS.
Feb 27, 2011 | Dell Inspiron 1525 Laptop Jet Black
Linksys e3000 router. I am able to connect to the router without typing in a password. Under encryption on the computer its states "none". How do I enable encryption on the e3000? Thanks.
Open the web browser on your computer and type ''http://192.168.1.1". This address will open the configuration page for the router. When you are prompted for a login name and password to begin configuration, just type 'admin' in both boxes to gain access.
Enable WPA2 Encryption
Under the wireless security tab, enable WPA2 encryption by ticking the appropriate check box. This will encrypt all data that is transmitted over the network. If the data is intercepted by anyone, they will find it to be garbled data. To enable this setting, check out the 'Wireless Security' tab. Choose a long passphrase to use and write it down exactly, because you will have to enter this passphrase on every wireless device you want to connect to to router. (laptop, Wii, BluRay, iTouch, etc)
Feb 11, 2011 | Linksys E3000 Wireless Router
Pl explain where is the switch of Bluetooth in Gateway LT 23, and how to enable it, and how to copy the data of another laptop via bluetooth.
bluetooth is not designed for data copy first off the connection is rather slow compared to usb/firewire. the FN+BT key enables and disables
Jan 28, 2011 | Computers & Internet
Our router is visible for others and everyone has free access! how to block this router for others?(network is unprotected now without any password or whatever). Thanks in advance. E
  • Please follow the below instructions to protect your device:
  • Connect your computer to the router using a network cable, or you can connect to the router through a wireless connection. Note that your wireless card in your computer must be enabled.
  • Open your Web browser. Enter: http://192.168.1.1 in the address field. This is an internal IP address to access your router. Press the Enter Key.
  • When the password request appears leave the user name field blank. By default, the password is admin.
  • After logging in, you are not required to change the default administrative password. However, it's fully recommended that you change the default password by clicking on the Administration tab and Management. Enter a new password in the Password field and again in the Re-enter field to confirm.
  • I recommend setting the Remote Management item as Disable. It will be another layer of security for your router. With this configuration you can only access your router for programming using a standard Ethernet network cabling.
  • To save the new password, click Save Settings at the bottom of the page.
  • To avoid intruders accessing your wireless connection we'll start to work with the Wireless tab.
  • In the Basic Wireless Settings enter a name for your wireless network connection in the Wireless Network Name (SSID). Set the Wireless Broadcast to Disable.
  • When wireless clients survey the local area for wireless networks to associate with, they will detect the SSID broadcast by the Router if the Broadcast is enabled. Do not broadcast the Router SSID. It must be Disabled.
  • Note that your SSID should be set following similar rules for setting a password, e.g. at least 8 characters, a combination of letters, numbers and non consecutive characters.
  • Disabling the SSID broadcast is not a strong security setting, but it can help prevent intruders from sharing your WLAN. Remember to save your settings.
  • Enable network authentication and encryption. Listed in order strongest to weakest:
WPA2-PSK (data encryption TKIP or AES)
WPA-PSK (data encryption TKIP or AES)
WEP (256 Bit) - Weak, but better than no encryption
WEP (128 Bit) - Weaker, but better than no encryption
WEP (64 Bit) - Weakest, but better than no encryption
plz do rate the solution if got help
Nov 23, 2010 | Linksys Wireless-G Broadband Router
My pen doesen't work in my portable with vista but works in a computer with windows 7
Hello
Did you encrypt the USB memory drive while it was in the Windows 7 computer? This would prevent any other computer from seeing the USB drive.
Try using the drive on another comptuer - if the 3rd PC fails to read the drive, put it back in the Windows 7 computer and remove the data encryption from the drive.
The following link is from Microsoft TechNet and provides details on how to enable and disable BitLocker encryption from drives.
May 01, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cannot connect to internet
At most that I can gather from your post/description is that somehow the security setting has been enabled in your router. This would prevent access to the Internet by any PC tied to your network that do not use the said encryption (security) key.
Perhaps the best or the simplest would be to do a hard/full reset of your router. This way all will revert to default factory settings and the WEP, WPA, MAC security will be disabled. There usually is a recessed small reset button at the rear or bottom of most routers for this purpose.
Should this be not corrective, pls post back with information on modem brand/model and what PC(s) (desktops or laptops) and your ISP.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | NetGear DG834G Router
Dell Inspiron E1505 Notebook Logo
48 people viewed this question
Alun Cox
