Hi
If ever you replace the display PCB or the main controller PCB then you must set the size of the machine in to the memory of the controller. This should of been in the instruction sheet that came with the display.
This Is Fault Code 9 ,which indicates Size setting or size error . When you changed the display did you size your machine to the new display module? Did you get the re-size set of instructions with the new display board? Ring up where you brought the display from and i"m sure they can help.
If this appears in your screen it will be necessary to set the size of the Aqua smart....
1. Press and hold the SPIN button, then press the POWER button until three beeps are heard.
2. Press the FABRIC SOFTENER button once to size the machine.
3. Press the POWER button.
If nothing works you need to reset your machine, please check the bellow link to get the manual and check page 18 and 23 for the reset instructions.
http://www.fisherpaykel.com//admin/pdfs/pdf_usecares/3731_LCDLED_Aquasmart_FINAL.pdf
Please get back to us if you have further query else please accept the suggestion.
