Question about Ricoh Office Equipment & Supplies
Waste toner is full on Ricoh Aficio 1035. - Ricoh Office Equipment & Supplies
  • 37 Answers
If you open the right side cover you wil see a brown belt , it is called the transfer belt , if you look on the side of it it has got a brown plastic lecer that pulls up .Pull it up and the unit disengages and you can take it off .You eill see two springs on the sides of the unit , take it off . on the lefthand side is a plastic hook that holds the belt lift it up and the belt pulls out .underneath the belt is six screws on the black plastic cover take them out and lift up the cover , you will find the old waist toner in there , vacuum this out or throw it out , reassemble close cover and the message wil be gone ..hope this helps
Posted on Aug 14, 2008
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Used toner bottle is full
I'm going to assume you typed the model wrong, and that it is a 1035 like the header states. If this is the case, the used toner on these is inside the transfer belt unit.
Open the duplex unit if equipped, then open up the right-side door. Attached to the door is the transfer belt unit, as see below:
602d8058-7b67-4449-895f-e01b266fd371.jpgLift the lever as shown, then lift unit out of machine. There is a panel with 6 screws near the bottom of the unit, remove all 6 screws and remove the cover. Be very careful, this thing is going to be FULL of used toner, and will make one HUGE mess if not disposed of properly. Once emptied, put cover back on, re-install unit, close doors, and you should be good to go.
Jun 09, 2013 | Ricoh Aficio 1035 Copier
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio 2105 waste toner full indicates even if it was already empty, cleaned the bottle sensors still indicates full, how am i going to reset it?
Make sure the 2 waste toner are empty.
You have 2 bottles of waste.
1- Next the papaer trays
2- Next the development Unit
May 25, 2011 | Ricoh Aficio 2015 Copier
When making copies, half the copies come out black because of a toner leak. i have wiped out the area where the toner bottle sits and used a can of air to blow out the inside. now what?
Clean the waste toner collection bootle,under transfer belt,clean the toner bootle house and align the drum cleaning blade or chnage it.
Aug 19, 2009 | Ricoh Aficio 1035 Copier
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Ricoh 1035 Display Messages
Empty waste toner in transfer unit on the right side door.
Jul 03, 2008 | Ricoh Aficio 1035 Copier
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
125 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
