Question about Sennheiser RS 65 Consumer Headphones
Headphones cut in and out - distorted sound
My RS 65s worked awesome for 2-3 years, but suddenly things changed. Now they constantly cut in and out and the bass is all distorted. I cannot figure out if the batteries are done for, or whether it is a transmission problem or what. Any ideas? I need to know if I should just replace something or buy a whole new pair.
Dance_to_it -
I have had these great headphones over 15 years (I think!)
1. Are the batteries getting a full 8 hour charge?
2. Have you tried all 3 channel options?
3. Is there anything else close by that is an RF transmitter or receiver? If so, move the headphone base or other RF instrument away from each other.
4. If these are the original batteries you probably need new ones.
5. When purchasing new batteries I recommend original equipment Sennheiser BA151 batteries, not any other brand. I have tried 3 or 4 other brands, all with less than satisfying results. I have no affiliation with Sennheiser corp., just a consumer of their products (and Grado's for wired headphones)
-KWS
Posted on Feb 03, 2011
How do I get sound to my Sennheiser RS120 wireless headphones when it shows as working properly?
Dirty volume control on headphones. Try moving the volume control back and forth several times to clean off the contacts.
Dec 14, 2014 | Sennheiser RS 120 Consumer Headphones
Headphones keep going quiet.
I would return them and either get a new one from them or another manufacturer.
May 11, 2017 | Sennheiser RS 110 Consumer Headphones
The bass vibration suddenly stopped working I changed the battery turned the music up loud and still mo vibration. I constantly have the bass on Max, and if that is the problem then skullcandy should not...
Sounds like you blew out the sub-woofer in the headphones. You could replace them, or if you've only had them for a year (or less) you can use the warranty included and have them fix it. All you have to do is call them up and ship the headphones to them.
Their contact page is listed below:
http://www.skullcandy.com/contact-us.html
May 17, 2011 | Skull Candy Skullcandy Skullcrushers...
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
Mac - no output from EMI 6/2 external sound system
re install the mac drivers from mfg web sight
Aug 03, 2009 | Computers & Internet
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
Sound cuts out
Output short protection needs work.
Mar 29, 2009 | Audio Players & Recorders
Audiovox Infrared Headphones
My set has an led that glows red when on...if batteries in correctly, and switch on...do you have a red "POWER" indicator. If yes, & still no sound, 1-does the other set work? 2- either side of prob set work? 3-VOLUME up all the way? Could be bad receiver/bad speaker(s) bad vol switch.
IF no POWER led on, then 1-bad batteries 2-bad power switch 3-broken internal power lead/wire.
Kids are rough on these things...any sign was dropped, or dunked in a coke? REMOVE ear cushions are screws if yur inclined.... sk
Apr 08, 2008 | Audiovox (JHHO-110) Headphones
Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Jan 10, 2008 | Sennheiser HDR 130 Consumer Headphones
Noise from woofer
Double check all of your cables, but it sounds like the power supply may have died. If the sound is like a mains hum, then the power supply will need to be replaced. Is it an internal or external one ? If it's internal, are there any fuses accessible ?
Sounds obvious, but double check the speakers are all correctly plugged in, by removing and re-inserting them. Check the volume controls and and other switches too. Try plugging headphones into the audio outputs to confirm their is actually a signal present, as the speakers may be fine, but the source may be faulty or its configuration changed.
Nov 20, 2007 | Car Audio & Video
Sennheiser RS 65 Consumer Headphones Logo
422 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
