Hard Drive I want to install an "infected" Samsung SP2504C internal hard drive as a secondary hard drive on my computer, in order to apply my virus software to it; Unfortunately, I have no idea how to do this. How would I go about this? Thank You. I'm currently using a Seagate Barracuda 7200.11 as the primary and I'm running Vista Home Premium.
  • 796 Answers
You will be able to connect this samsung hard drive which is a SERIAL ATA drive if you the SATA port on ***********-board(remove the jumper from the hard drive)...
after you are connected ,in your bios set the seagate as your primary booting device.....
after this is done you can continue the virus software
thankyou,.
regards
JC
Posted on Aug 13, 2008
MY HARD DRIVE IS CORRUMPTED. ASK ME TO FORMAT THE HARD DRIVE BUT I WILL LOSE ALL MY DATA
  • Attach it as secondary drive on another computer. USB or internal. You should be able to access the data.
  • Go to Start > Run (Search). Type cmd ENTER. From the Command Prompt type chkdsk x: /r/f ENTER. X being the drive letter.
  • Whatever Word documents do not get repaired, open in Wordpad to see and extract data.
Oct 21, 2012 | Samsung HM251HI 250GB 5400RPM 8MB 2.5"...
My Dell PC scan says that my Samsung SP2504C hard drive is about to fail and should be replaced. Is this something I can do?
Replacing the hard drive involves the following process:
  1. Turn off and unplug the computer
  2. Remove the two screws from the left panel (facing the front of the tower)
  3. Slide the left panel back and to the left to remove it
  4. Unplug both power and data from the hard drive
  5. Unscrew the hard drive (You may need also remove the right panel to get to additional screws)
  6. Slide hard drive out
  7. Slide in new hard drive.
  8. Screw in new hard drive in approximately the same fashion as previous hard drive was screwed in
  9. Plug in power and data
  10. Re-install panel
  11. Plug computer in and boot
However, if this is your main or only hard drive, you will need to install your Operating system and all of your software and files from scratch. It may be possible to preserve them, but that's often risky and requires a bit more work. If this is your main hard drive, you probably want to consult an expert on having the old drive contents moved to the new drive.
If you like my solution, please vote for me,
Apr 09, 2011 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Hello
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Good LUCK AND DO RATE THE SOLUTION IF HELPS
Dec 20, 2010 | Compaq Computers & Internet
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
My pc tells me that I'm running out of hard drive
You can use either.
You can also use external portable hard disk, you can move all your software and stuff to it.
Better would be installing a new operating system to new hard **** with larger capacity, it will make your system fast.
You can also fit hard disk in your computer PC cabinet, you will just need to set it as "Slave" or secondary hard disk, to do this, setting is available on the hard disk.
Nov 03, 2009 | Compaq Evo D500 PC Desktop
How do I interface a 2ndery hard drive?
I would suggest that you buy a cheap USB2 to IDE converter from EBAY (they are a few pounds shipped in about a week from Hong Kong). You can use the power from the PC PSU and attach the drive to the USB cable, and then plug it in once your PC is running.
That way, there is no risk that you will boot from your drive when you re-attach it to your PC because you will already be running and can "hot plug" it. Best to turn off AutoRun first, then plug in your drive using your new USB cable and browse around it for the files you want. Make sure you virus-scan any files before running them on your newly disinfected system!
Once your drive is attached, you can virus-scan it, but might be better to salvage the files you wnat and then re-format the old drive. You can leave it attached internally via the USB (just run the wire out throu' a PCI slot hole if you have no internal USB ports, or you can change the little black jumpers on the back to "slave" mode and attach it to the spare plug on the IDE ribbon-cable of either your HD or your CD-ROM. Which you choose would depend how worried you are about the speed of your various drives.
Hope that's some use.
Aug 14, 2008 | Computers & Internet
Hard drive Problem
as long as your primary drive is protected with a virus software dont worry about it. Unplug your cd rom ribbon cable and interface the other infected drive to ide1 or ide 0 whichever way dont try to master slave them. Let windows see the other drive as another drive, then the software should handle the infection.
Pending on the infection you've got the partitions may or may not matter, your better off with a solid parition, less seek times to the data anyway.
Aug 12, 2008 | Computers & Internet
Installing Hiotachi Deskstar 400gb hard drive
in order to set it to slave you first needs to make sure the cable that u hoodked up to the hard drive is the slave not secondary then boot the computer to the bios and then under the ide section section you need to ensure that the hard drive is recognized as primary slave it will show the hard drive as a primary or a secondary that will let you you that u have the cable hooked up to the harddrive right if not usee the other connector on the same cabel and repeat the bios settings i know it sounds hard but it really is not good luck !!!!
Aug 09, 2008 | Computers & Internet
250GB harddisk only 130GB
try downloading any program that manages disks (partition magic for example ) and see if all the space appearsin that program, if so asign to that space a drive letter and format it .... (with the program that u will use )
Jan 16, 2008 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
