Sata drive problem
MSI K8MM
Can't see active SATA drive in my Bios, when I boot and select tab, to go into raid configuration, all options greyed out. I try and run an install cd, and I cannot see my sata drive .
Will appreciate any help
thanks
John
  • Wilton Itamoto
    Wilton Itamoto Dec 17, 2008
    I have the same problem. My sata drive is not seen in the bios. I looked in the bios and can see the ide drives but nowhere can I find references to my sata drive. Where is the settingsin the bios to configure the sata drive located?
    Motherboard Epox 8KMM3I-X
  • Samuraix4148 Apr 15, 2009
    I have same problem..May motherboard id K8MM-V...
    Also the windows the cannot when i attach SATA DVD-RW on the sata port...Why,,,,??
    Need help..Thank you...
    Brigadier General:
  • 6,966 Answers
Depending on the brand and model of the motherboard, your concern is indicative that the SATA is not enabled. Pls enable, save and exit, reboot. Thereafter enter CMOS/BIOS again to auto/manually detect.
Hope this be of initial help/idea. Pls post back brand & model of your motherboard, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 15, 2008
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
I've ms-7142 v:1 model mother board in this bios this not showing the sata option will u plz help me out of this...
go into the bois and make sure the sata raid or raid option is enabled, that should fix it
Oct 08, 2009 | MSI K8MM-V Motherboard
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Need to boot from SATA drive
If you only have one SATA drive, you do not need to have the RAID setting turned on in CMOS. RAID is only for 2 or more SATA or SCSI drives. Shut that off and try again.
Mar 14, 2009 | Computers & Internet
Sata Port Connector is not avtivating
I had the similar problem with the K8MM-V Motherboard. I has been using a PATA HDD. I need to intall a 250Gig Seagate SATA HDD. Despit all the Bios Configs the PC Could not detec the HDD. Untill i Put a Jumper on the HDD  limiting the SATA HDD to 1.5gig of OS instead of 3gig. Look at the Label of your HDD
Oct 28, 2008 | MSI K8MM-V Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Windows Installation gives blue screen errors.
Hi, at the boot up go into your bios [ on MSI press the delte key continuosly] and turn OFF the onboard virus protection. This can block all O/S from loading as they need to write to the bios in the installation process. Ensure you turn it back on after installation, it is there to stop hackers getting into your bios and wrecking your system. Regards mistyman
Sep 04, 2007 | MSI K8MM-V Motherboard
Computers & Internet Logo
1,145 people viewed this question
David Payne
David Payne
