Question about Video Game Consoles & Games
My x-box controller works intermittently, it is not a wireless one. Could there be a problem with the connection
    Problem Solver:
  • 22 Answers
Try using another controller. if the other controller works fine, it means your controller is faulty, if not, there is something wrong with your xbox or xbox controller port. try isolating that problem first and then come back here if it doesn't help.
Posted on Aug 13, 2008
Touch buttons on x box 360 not working
If buttons of your controller is not working we need to check the ff: Wireless controller: 1. Check the wireless adapter if properly connected. 2. Reseat the wireless adapter. 3. Check if you are getting stable green lights in front of the xbox for connection notification. TIP: It will be better if your wireless adapter is the wireless-N adapter. 4. You can check other wireless device to connect to xbox to isolate adapter issues. 5. If adapter is failing, replacement is needed. Wired controller: 1. Controller needs to be checked. 2. Controller needs to be tried to a friends xbox. If working,port might be faulty. 3. If controller seems not to work with a different xbox.controller needs to be replaced. Thanks for choosing www.fixya.com
Dec 05, 2011 | Microsoft Video Game Consoles & Games
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
How do you connect a wireless Controller to the XBOX console?
what you do is hit the x-box symbol on the controller while hitting it on the actual x-box
I hope it works, if not then consult an expert.(not that i am not an expert.)
Jan 31, 2010 | Gamestop Edge Wireless Controller for Xbox...
Wireless connection is intermittent
You may have interference with other devices in the same range as your router.
If you have Vonage then you may have issues with some routers also. If you do have Vonage, then try to make sure your router is not on the same leg of your networ as your vonage modem.
Aug 04, 2009 | Computers & Internet
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
May 10, 2009 | Linksys WRT160N Wireless Router
X Box 360 controler for pc doesn't wanna work for my X Box 360
click the button on the front of the 360 console...
which is to the right of the memory slots... when the ring of light is spinning around click the button on the top of the controller... it will then connect to that system.
There after it will always look for that system. so if you want to connect to a new system you push the button on the front of the system and then the button on top of the controller.....
Mar 18, 2009 | Microsoft Xbox 360 Controller
Wireless signal intermittent
First make sure you have the latest update for your bios and wireless device, your os is probably non preload so clean any access connections utility provided by ibm, rather than using the ibm thinkvantage access connection make sure to use the windows own utility to control the wireless device
Feb 11, 2009 | IBM ThinkPad T43 Notebook
Windows xp no longer recognizes my wireless antenna/program
To change windows to the controlling program, click on Start, then head over to Control Panel. Under Control Panel, double click on the icon for Network Connections. There, find the Wireless Network Connection. Right mouse click on it and go to properties. After the Properties Window pops up, Click on the Wireless Networks Tab. There, check mark the box which says "Use Windows to configure my wireless network settings." This will activate windows control over the network card. Hopefully this helps.
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Not connecting
There should be a switch on the Pelican wireless controller that enables you to change the channel on the controller and or receiver. Look in its manual, it should say such. If not... Then it's because it is a very poorly-done job done by the company. Replace that controller with a WaveBird (older wireless controller for the gamecube, but a lot better)
Please keep your X-Box controller question in another section.
Aug 03, 2008 | Video Game Consoles & Games
Intermittent connection to wireless network
Two possibilities to consider --
There are reports the combination of a hidden SSID and WEP/WPA encryption causes intermittent connections using Windows. Recommended solution to show the SSID instead of hiding it.
Second possibility consider changing the channel the wireless communicates on in the router from the often default 6 to 1 or 11 to see if you can avoid interference on channel 6. Try the other channel if the first does not work. Interference is not only from routers but can be from in house wireless phones and other devices.
Dec 22, 2007 | IBM ThinkPad T43 Notebook
Video Game Consoles & Games Logo
35 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
