Question about Dell InspironTM 1501 Notebook
Blue screen with rows of white lines (not BSOD) causing laptop crash
I'm randomely seeing laptop crashes where a blue screen is displayed with white vertical lines (seen these lines described as similar to barcodes). The laptop hangs and I need to recyle power (remove battery) to try a restart. I've had the Dell laptop since about Jan 2007 (Vista w/ no SPs) & this problem just started about a week ago. The only thing I installed recently (that I recall) was VPN client. Any ideas on how to fix this? I haven't tried uninstalling VPN yet.
  • j p Dec 10, 2008
    yup same problem, tried cleaning the hard drive completely but still does it. usually once or twice a day. but new hard drive sounds nice... hmmm
  • junebug34820 Apr 11, 2009
    my inspiron 6000 has now started crashing. It would load and when all the icons have appeared it goes to this blue screen with white letters. Can anyone help me with this?
    Genius:
  • 2,028 Answers
A blue screen generally indicates an operating system error or hard drive failure. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive won't format, or you have any issues during or after the install, then the hard drive has failed and will need replaced. You will need an operating system or recovery disc in order to do this. If this is a preloaded machine that didn't come with any discs, then you will need to acquire the disc.
Posted on Aug 13, 2008
Tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 | Computers & Internet
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
Screen is completely black now. When I try to boot up sometimes it will but then a blue screen with lines on it comes up then it goes blank and can't get it back
Blue screen errors are mostly associated with RAM problem or software issues. You can try reseating the RAM or it might need to be replaced.
Jun 09, 2010 | HP Compaq Presario V2000 Notebook
My laptop has come up with a blue error screen and will not let me in. The screen says "A problem has been detected and windows has been shut down to prevent damage to your computer.... Technical...
Don't give up try booting into SAFE MODE press F8 at bootup and choose safe mode, with networking. Then at least you can troubleshoot what is wrong, it is often a bad Video driver. It may require reinstalling or updating, or some other driver that is giving you this BSOD.
Feb 01, 2010 | Computers & Internet
Plugged in the 1TB WD My Book Essential into my Dell Dimension 3100 running windows xp and the screen goes blue and I get a error stating "Bad_Pool_Header"
here's a solution I found on google:
BSOD the Solution:
Did you install Service Pack 2? Are you now suffering from the Blue Screen of Death (BSOD)?. Here is the solution. I have spent 4 days hunting down the cause of my machine crashing and have finally cracked it. Maybe other people have a different cause than mine so my solution may not work for everyone.
After installing SP2 I suffered many crashes. In particular the Screen would turn blue and display a message starting "Bad_Pool_Header". And ending with STOP: 0X000000019....
Then my four day hunt for the cause started.
BSOD Solution
Basically I found two causes of the BSOD.
Cause 1: Corrupted file or folder.
Cause 2: Microsoft Indexing Service
Possibly these two causes are linked.
Solution for Cause 1
Onen up Explore (right click the start button), and expand your directory tree, starting from the C: drive. Click on each folder in turn and see if any cause the BSOD to appear. If so, reboot, and simply attempt to copy the folder, and then delete it.
Solution for Cause No 2
Switch off Microsoft's indexing service. You can do this by clicking the start button, select "Run", then type "msconfig", then select the "Services" TAB, scroll down to the Indexing Service and Switch it off. Reboot your computer, and good luck - maybe it will work, It solved the problem for me.
At first I thought I must have a third party software or hardware conflicting with SP2, but even after I had disconnected the internet, switched off all items in the startup TAB of msconfig, was still getting the BSOD. I tried surface scans, chkdsk, scan disk etc all to no avail. I tried defragmenting the disk, but the frequent crashes may have made things worse.
I discovered the computer was now crashing after about 7.5 minutes of being switched on. It did not matter whether anyone logged in or not.
Finally I went to msconfig (Start Run, MSCONFIG) and switched off "process System.ini files, Load System files, Load Startup Items. And the comuter stopped crashing. So then I added the item back one by one until I discovered the Microsoft Corporation Indexing Service which was causing the crash. I switched it off and switched everything else back on and AT LAST... No more BSOD
Jan 01, 2010 | Western Digital My Book Essential 1TB...
Oribcam causing system crash on acer 5630 model with the following blue screen of death error message lv321av.sys as the cause of the issue.
Hello the problem came from the hires of the webcam into the laptop .with the times the hires become old and fragile and if you move in the bad positionthe webcam or the base of the laptop you will crash with the so beautiful (BSD bleu screen of death)
Sorry for my english i am french
yeah sarko land !!!!
Apr 23, 2008 | Computers & Internet
Dell InspironTM 1501 Notebook Logo
1,745 people viewed this question
Alun Cox
