Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13 our dishwasher has come up with a E4 code flashing. Do you know how to get rid of this?
E4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Posted on Dec 02, 2008
My dishwasher will not start and the plates light keeps flashing, what does this mean and what can I do to fix this. Thanks
Here is a link to the error codes for your washer. http://www.manualslib.com/manual/213875/Baumatic-Bdw13.html?page=25
Also, another link to an incredible source of info on a whole host of manufacturers' diagnostic routines--your model is on page 19, includes how to enter diagnostic mode, etc. I hope this helps you!
Oct 04, 2015 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dont know how to clean the dishwasher
go to the dishwashers brand site,click help for your solution.
Jan 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
E4 message
take of the btwo black panels at the bottom of the dishwasher and put in a towel to soak up thje excess water this works for me everytime
Jul 31, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Beumatic
OK - sorted it finally!
If you, like me, had actually added water thinking that this would rinse the machine through... doh! you had inadvertantly made water fill the cavity at the bottom of the maching. This is situated behind the kick-board. There are 2 black plastic panels - if you remove these, (they just pop out) and sponge out the water that is activating the dip switch (there is a polystirene float) that activates the pump - this resolves the E4 error code.
Make sure you do it while the machine is off! The reason the base of the machine has filled with water may need further investigation, but mine was most definitely user error. Who'd of thought adding water to a dishwasher could have been so fatal! It nearly cost me £88 call out charge too after the helpline weren't able to help me.
Jun 25, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Mar 08, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
665 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
