Computers & Internet Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot connect to the internet...says that a client is missing or does not start. I cannot connect it to the internet to see which drivers are needed. Just need an idea where to get all drivers needed for this desktop.
jose de jesus sigala
Level 2:
New Friend:
  • Expert 134 Answers
  • Posted on May 13, 2011
Expert
Level 2:
New Friend:
Answers
134
Questions
Helped
25588
Points
233
You are connecting to internet thru a lan ,usb port, modem give me more details in order to help you
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
How to install my router for wireless internet on my laptop.
1. Purchase a wireless router that fits your needs and price range.
2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
7. Click on "Properties."
8. Select the "Wireless Networks" tab.
9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
10. Click on "Configure" when you see your network's SSID in the "Available Networks."
11. Enter your network's SSID and WEP key.
12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Thanks.
Have great day.
1helpful
My internet can not connect or start i thik some ier missing
Download drivers for internet connections..LAN drivers, WAN drivers...
Openvpn Network Connection
u can do that with IP routing or with default gateway. Try to give one default route for destination.
1helpful
Can not get the IP
Make sure that your security1.gif password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless1.gif zero client are started and set to startup type automatic.
2answers
Modem issues
If you are using wireless, make sure that the password is correct...
Then:
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
If not wireless.Unplug your router and modem for a few minutes.Then restart your computer, and plug the router and modem back in...
2answers
My router is failing
I have had many D-Link routers fail ova the years and they all seem to start off just as ya describe , then go toes up... after a bit. Of course B4 getting another unit, one must first re-install all drivers, check all cords, cables etc. just to rule out anything else. Then get a nice new modern one :)
Top Premier Computers & Internet Experts
goneforever.
ADMIN Eric
ADMIN Eric
Behailu Mekonnen...
Behailu Mekonnen...
Level 1 Expert
Are you a Premier Computer and Internet Expert? Answer questions, earn points and help others
