Question about Xerox Office Equipment & Supplies
Xerox Repair I have a Xerox copycentre C35 that requires a maintenance service contract. could you recommend a comany that does this.
  • Anonymous Mar 21, 2014
    Does it have memory?
    President:
  • 2,072 Answers
Either Xerox or Global Imaging. You can go on to Xerox.com and look for a local ASP, Authorised Service Provider. they list them by city and area code.
Posted on Aug 13, 2008
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
After all checks and maintenance on a xerox copycentre c20 the copy is still blink.
Will it still run the billing meter report? Is there print on the paper when you print the report?
If so, the issue is with the scanner. If not then the issue is the laser.
Feb 07, 2011 | Xerox Office Equipment & Supplies
How do I do a password for the machine Xerox CopyCentre C128
Click on the link below and select to view the Xerox CopyCentre C128 owners manualm inside the manual will show you how to set the password
http://www.support.xerox.com/support/copycentre-c123-c128/documentation/enus.html
Dec 19, 2010 | Xerox CopyCentre C128 Black and White...
Which toner I could use for copycenter c20?
Use OEM. Xerox cartridges only if you want reliable clear prints.
I have tried many different generics. I wouldnt recommend using anything but the OEM cartridge. They just perform better.
Oct 23, 2010 | Xerox CopyCentre C20 Black and White...
CopyCentre C123 Copier Copier: CODE 116-331...
It may be a defective Main System Controller board 160K91660 or Hard Drive 960K01120.
There is a diagnostic which requires the Xerox Technician's Laptop to test the Hard Drive.
You might get lucky just reseating the Hard Drive.
Whit
Item, Inc.
May 17, 2010 | Xerox CopyCentre C123 Copier Copier
Error code 07.009.42 what should I do?
07,009.42 Error indicates that the printhead was unable to tilt normally on its axis.
This is most likely caused by a cracked drum maintenance camshaft. The drum maintenance camshaft is driven by the process drive motor on the right side of the printer. It raises and lowers the maintenance kit against the drum to oil and clean the drum. The camshaft has 2 lobes on it. These lobes crack over time and cause several different error conditions. The camshaft part # 401100380 is only about US$20 from Xerox but can be very difficult to replace. Also look at the pivot plate assembly. Slide out the drum maintenance kit. If you look inside the cavity the plate that the maintenance kit sits on is called the pivot plate. If the drum maintenance pivot plate is white plastic it should also be replaced with the new style black plastic plate. This requires removing the process drive gears assembly. Note that reinstalling the assembly requires the gears to be accurately timed. This repair should only be performed by a qualified technician.
Mar 24, 2010 | Xerox Phaser 8400 Laser Printer
"Power Up Failed" Error
On this product you may need to have Xerox to come repair the copy machine.
This problem maybe more involved than anyone can assist to correct it on this site.
Also, depending on the call charge if all parts and labor are included with the charge, "PAY THE $400.00 FOR THE REPAIR VISIT."
It is well worth it! Besides Xerox will warrenty the service call for 30 days.
Oct 11, 2009 | Xerox CopyCentre C65 Black and White...
Have XDL33 Copier. Has been out of service for a while because when turn it on get u42 error code. Had this code several times before while it was under maintenance contract and only took tech a few...
Hello sir; Yes, you can do it by youself,just follow my instruction;
Open front door , hold 0 while you turn on power then enter 50 press start key, enter 20 press start key again, then close door turn power off and back on.
Aug 20, 2009 | Xerox XDL-33D Black and White Copier
I need Know, How enter to service mode
Press,,,,, Menu #1934 . What you may want to try first is to do what is called the Shading adjustment. That calibrates the scanner.
It would be found in the maintenance menu after you enter diagnostics.
You must place 5 pieces of white paper on the glass before you perform the adjustment.
There really is no way to increase the amount of toner concentration on that machine. You may very well have a defective ink cartridge. That is not uncommon on the C20. There is a metering blade in the toner cartridge that often times does not allow enough ink to be applied to the toner roller.
May 13, 2009 | Xerox CopyCentre C20 Black and White...
Part description
Yeah. But if you don't have a maintenance contract, call a dealer service department. You can go to Xerox.com and locate a dealer near you. Xerox would cost more than the printer just to show up.
Jul 22, 2008 | Xerox Phaser 8400 Laser Printer
170 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
