Question about Whirlpool Duet GHW9150P Front Load Washer
Duet Dryer stuck on "Quick Dry"
My Whirlpool Duet Dryer is stuck on the Manual Cycle "Quick Dry" and displays a time of 23 (which is the default time). I am unable to set the control knob to any other setting , Manual or Automatic. I am able to set "more time" to allow for additional time in the Quick Dry setting.
Can you help me get the control knob to function properly again?
  • ddeguz May 18, 2009
    I have the exact same issue- any suggestions, oh appliance gurus?
  • 641 Answers
SOURCE: Dryer Not drying well
Check first: That the lint filter is clean. That the duct from the dryer to the outside of the house is clean. In case it will not solve your problem,it might be an heating element issue (partially burned). The dryer will still heat but at such a low temp, that you will need for extra time to get things dry. Open the rear panel, look for the heating element and check visually that there is no burned parts on it (disconnected coils). If there are a burned signs on it, you should replace it. Good luck !!
Posted on Jun 16, 2006
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet front loasding automatic washer
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@!@
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet GEW9200L control
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet dryer wont start. Lights up
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
marka19
  • 1430 Answers
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Nov 26, 2010
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Hi, I have a Whirlpool Duet dryer stuck in control lock mode. I have tried to hold the "End of Cycle Signal" button for several seconds but this has not remedied my current situation I hate to have spent...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer is stuck on control lock mode. Have tried pressing the end of cycle button for several seconds and control lock button stays on....dryer won't run.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Jun 27, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer stuck on control lock mode
Jun 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Duet front load washer door locked & will not cont wash cycle
you can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water in the unit this should unlock your door then you can check the drain pump for anything that may be restricting or blocking the drain pump
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer Lockout function stuck
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool duet sport washing machine has F-28 error
i have the same problem... and i got it fixed 3 times.. the frist time.. there was stuff stuck in the pump... but every time i go look in the pump.. theres nuthing and i still get f-23... good luck..
Jan 21, 2010 | Whirlpool AWM9000 Front Load Washer
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal De
