Question about HP DeskJet 3820 InkJet Printer
Hp deskjet 3820
The ink cartridges get stuck on the right side. The is a square white looks as if a resting area. I don't know if it's the right position.
  • 2 more comments
  • cmoulton187 Aug 28, 2008
    no paper jam and the ink cartridge will not move
  • Anonymous Oct 18, 2008
    same issue
  • Anonymous Nov 01, 2008
    same thing. It's stuck and makes periodic tick sounds.
  • Anonymous Apr 11, 2009
    stuck on right side. resume and power lights flashing. won't print at all. brand new cartridges. very annoying!
The ink cartridges get stuck on the right side. The is a square white looks as if a resting area. I don't know how to fix it.
Posted on Aug 19, 2008
DRAYVERS
Posted on Aug 30, 2008
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
WHAT DOES THE TOP TEAR DROP SHAPED BUTTON MEAN WHEN IT IS FLASHING ON A HP DESKJET 3820
The flashing teardrop light indicates your ink is about out.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | HP DeskJet 3820 InkJet Printer
There is ink but ink light is blinking and not
if its a refilled cartridge then... it might be a bad one... my best suggestion is called hp and verify the ink install procedures... or consult your manual... if you did it right then you might have a bum cartridge... replace it and try again... if the same then you might need to get your hp repaired...
Dec 22, 2009 | HP DeskJet 3820 InkJet Printer
My HP 3820 has the bottom two light blinking.
Try setting it up again or buying a new cartridge
thanks bye
Oct 12, 2009 | HP DeskJet 3820 InkJet Printer
Your advertising is misleading
Follow this link to the recycling area: http://www.hp.com/hpinfo/globalcitizenship/environment/recycle/
Dec 01, 2008 | HP DeskJet F380 All-In-One Printer
Hp deskjet 3820 - have refilled the cartridge and pc wont print
Clean the contacts on the carriage with piece of cotton and then clean the contacts on the cartridge with rubber and try again. If this not help replace the cartridge.
Oct 25, 2008 | Apple HP DeskJet 3820 InkJet Printer
Print cartridge
This may sound simple, but did you remember to remove the tape covering from the ink cartridge before installing it? If so, run a self-test and let me know the results:
1. Turn the printer ON.
2. Press and hold the POWER button.
3. Press the RESUME button FOUR times.
4. Release the POWER button.
You should get a nicely printed self-test. If it fails, there may be other troubleshooting methods we can employ.
I hope this helps!
Regards,
Char1ieJ
Sep 08, 2008 | HP DeskJet 3820 InkJet Printer
Hp deskjet 3820
Take the cartridge out and clean it with a qtip and reinstall it.
Jul 06, 2008 | HP DeskJet 3820 InkJet Printer
REPLACED INK AND STILL NOT WORKING
Due to shiaty design, it is easy to accidentaly puncture the printed circuit with the sharp end of the retention spring while inserting a new cartridge. Use a flashlight too look at the white/copper sheet the cartridge makes contact with and look for a puncture (probably near the lower right side.)
Mar 15, 2007 | HP Deskjet 6940 InkJet Printer
Cartridges not moving
Sounds like a corrupt driver, uninstall your printer (Start> Printers and Faxes on right column), select your printer icon, right click>Delete. Disconnect your printer and re install drivers first, then reconnect printer when prompted. If still not performing correctly suspect printer head carrier fault.
Oct 25, 2006 | Apple HP DeskJet 3820 InkJet Printer
HP DeskJet 3820 InkJet Printer Logo
723 people viewed this question
Seeker5211
Seeker5211
