I have purchased the Samsung DVD-VR375 DVD Recorder / VCR and want to unlock the regional code on the machine. Can someone please tell me in detailed step form how to do this please?? Greatly appreciate your help Thank YouChris
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
I also had the region 1 problem. It seems the code 29334 doesn´t work for machines bought at US. Does any one have an alternative solution?
I went to the suggested website, (under Try this site) and they did have the Samsung DVD-VR375 listed and I will try their solution later. However, you need to pay to get access to the codes
Try this site
That might be a new model to have in the data base yet but someone on that site can help you.
Hey thanks for that, I just checked their site and you are right, the
VR375 isn't even listed on their database ;(
Any other suggestions?
Mee too. Everywhere I look the player does not appear. Can anyone help with making this thing region free?
Hi I've just purchased a Samsung DVD/VCR VR375 combo region 4 and would loev the unlock as I have some UK DVDs I brought with me to Aus when I moved and it will not play them.
I need the receiving code for the Samsung DVD-VR375 DVD Recorder/VCR Combo
it didn't work for me what could the problem be?
trying to use this decoding method...with no luck. After you go into menu, which function should you be on? All I can get is timer or setup. Thanks.
Not working for me. After pressing menu, the timer menu comes up, but no place to enter numbers.
I have tried the 29334 code on a region 1 machine with no luck :-(
I have the same problem, it seems that the newer players do not accept this hack, is there anyone else with a different suggestion
did not work on US region 1 machine. Does anyone have a new solution?
I find region free code....
Samsung DVD-VR375 DVD Recorder / VCR and we tried to change the multiregion code and we cant do it can you help us plz??
For Region 1 players these methods don't work. I have tried so many times. Perhaps someone will find an answer for Region 1 players.
The solution posted by stewarthunte worked perfectly for me. I'm in New Zealand (region 4).
need dvd vr375 code
Please tell how I can solve the video problem in my dvd-vr375.
region free
