Question about Apple InFocus X1 Multimedia Projector
Your comments In answer to your questions, the projector gives an image that is white, so the bulb is lighting up, but there is no image other than the white light. I've tried linking it up to both computer and dvd players, but nothing else appears. It has worked fine until recently.
  • 2,239 Answers
You need to replace the controller eca (main board)
Posted on Sep 04, 2009
SOURCE:
I have 2 epson EX31 projectors in our sanctuary that run the same image from the MAC. (song lyrics, slides, etc) Recently I replaced a bulb in one...and since then...the "White" levels in the projecto
If uniformity of the images is important, I would reccommend replacing the second bulb on the other projector with the same bulb, from the same vendor as you did the first. It may be too difficult to match them up otherwise (assuming the first bulb you bought isn't defective).
I hope this helps,
--Robert
Oct 29, 2014 | Epson EX31 Projector
How do u know when to replace the bulb ? Does ig just go off instantly or is there warning signs ? I have white specks appearing on my images thanx val x
It is not correlated with the lamp
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip. I supply it ,USD200
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 04, 2014 | Acer X1130P 3D Ready DLP Projector...
Clean light engine
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jan 16, 2014 | BenQ (200NSH-LAMP) Projector Lamp for...
I can't get my Vivitek projector a d952hd model to show light anymore - it is only 6 months old and I doubt it is the bulb as it looks new and the image had not diminished at all in recent weeks - we...
hi,
All projectors have self dioganisng function. If there is any malfuction inside the projector it will indicated by the LED blinking. You have to inspect how many time the LED blinks or which LED lights condinuosly. LED meas the power light or the lamp light. Then only anybody can suggest you a better solution.
ok
Jun 21, 2011 | Vivitek D825MX DLP Projector
I have a question regarding the distance I can achieve with the Dell
The Dell 2400MP Projector is rated for 1-2 to 12 meters, or 3.9 feet to 39 feet.
However, the farther the distance to the screen, the dimmer the image will be.
A great resource for Dell Projectors is this link: http://www.projectorcentral.com/Dell-2400MP-projection-calculator-pro.htm
It leads to a little flash tool that allows you to use sliders to adjust throwing distance and then tells you how much light you can expect the wall. It also gives you a ton of other useful information about the projector.
hope this answers your question
D.
May 02, 2011 | Dell 2400MP DLP Projector
All areas that should project white are yellow could this mean bulb is getting old or maybe the settings of the compoter its hooked upto need to be chnaged please advise
If the screen is getting more yellow, that is due to either an old bulb, not producing so much high frequency light, or the blue LCD imager is dirty/burnt or the mirrors require specialist cleaning.
Cleaning the LCD units and mirrors takes about 2 hours to complete including re converging.
Hope that gives you an idea.
Dec 31, 2010 | InFocus Proxima UltraLight LS2 Multimedia...
HD72 image has no color (black and white only)
it could just be a setting issue. go into the menu and reset the settings to the factory default.
Aug 07, 2009 | Optoma HD72 Multimedia Projector
I have purchased a new lamp... the second one... when I turn on the projector, fan comes on then both red lights... one flashing. What can be the problem? Second new bulb... so pretty sure it isnt the...
you need to give more information. what is the make? the model? the type (lcd or dlp)? you can't expect a detailed answer without a detailed question.
Aug 05, 2009 | Office Equipment & Supplies
Have power, but no image
I have gone through two bulbs in the last nine months. When I was searching for an answer I found a website which is investigating a possibnle class action suit against Sharp because of poor bulbs. If anyone wants the info I can pass it on to them.
Jan 12, 2009 | Sharp XR-10X Multimedia Projector
Reply to your question
One more question... when you plugged the projector in ac outlet, did it give smoke, smell or something?
Jul 24, 2008 | NEC VT460 Multimedia Projector
Apple InFocus X1 Multimedia Projector Logo
112 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Alun Cox
Abdul Mannan
Abdul Mannan
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
