see this step: God bless you
Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset
the circuit breaker. Then turn the central vacuum unit on. If the
circuit breaker trips again, then refer to the following:
Determine if the house circuit your vacuum unit is on has sufficient voltage required.
If your unit has a reset button, press the button and try again.
Cross
the low voltage wire from the relay at the unit with a small screw
driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
