Sony trinatron 36". tv comes on with sound and no picture. red light flashing continusly. after awhile aclick is heard and picture comes. moved tv a nd now hve sound but no picture. advice please.
  • radar 1 Aug 13, 2008
    model kv35v36 and yes light blinks
  • radar 1 Aug 14, 2008
    thanks for your input. I think that I will probably just get a new tv.
    can get a magnavox 50" or 47" 768p/1080p/respectivly for 1000.00
  • 4,234 Answers
I may know the problem, but without the model number I can not be sure. Can you please post the model number? Also, when the set is on, does the standby light continue to blink?
Thanks,
Dan
Posted on Aug 13, 2008
  • ABRsvcs Aug 13, 2008
    Ok. Thanks for the update. Lets try the simple things first. I suspect that the picture tube is starting to fail. I am assuming that the standby light continues to blink. With the sound working, this is normal as long as the picture pops up in a few seconds. If not, then the next step is to turn up the screen control SLIGHTLY. If you open up the back cover, the flyback transformer will be seen toward the rear of the set. This is the part with the large red wire coming out the top. There should be 2 controls on this part. With the set on, turn the top one slightly clockwise. This should make the picture pop on. If it does, then you have given yourself enough time to search for a replacement set as this means that the picture tube is on its way out. If that failes to resolve the problem, let me know and we'll look further.
    Dan
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
2000 Sony Trinatron #KV-36FV26
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
May 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv takes a minute to get picture
Greg , Sounds like a bad "jungle IC" but without knowing specific voltages it`s really hard to say, picture should show up in approximately 15 seconds not a full minute, it`s normal for the audio to be heard almost instantly way ahead of the video, part number for the IC is 875210104, generic number is cxa2154as, be prepared they are not cheap IC`s, I would probably run the set for awhile and see if it gets worse as time goes by. good luck
Nov 27, 2007 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
