Question about Video Game Consoles & Games
Vertical lines in picture when running Playstaion 3
  • waiwah Oct 06, 2008
    I have same issue with him..
    Tried different cable.. hdmi..av cable.. component cable.. and tv
    please help.
  • hug7564 Feb 03, 2009
    I have a vertical line running across the screen when I use the Playstation3 to veiw BluRay movies.
    Master:
  • 788 Answers
Have you tried a different connection method, like S-Video or Compsite instead of component or HDMI? Have you tried another device on the same input on your TV or a different TV?
Posted on Aug 13, 2008
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
My playstaion 3 picture will not show up what
Try resetting the output signal to standard definition by holding the power button down for 5 seconds.
Hope this helps
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Getting a picture but double visioned and red lines running through it
This is 1 of 2 problems.
1; Convergence(depending on the model of the TV, the convergence ic's will have cold solder joints) 2: vertical ic issues.
If they are different colored lines & the picture also bends, it's a convergence problem. Else suspect a vertical problem. In the case of vertical issues, most of the time it's a defective capacitor (or cold solder joints.).
if it's the 3-crt kind of big screen, it's possible for one of the tubes to be going bad.
Feb 28, 2010 | Televison & Video
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Playstaion 3
Try using a different hard drive. The reader arm may be stuck on the platter inside your hard drive so it can't fully boot. Thanks.
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Video Game Consoles & Games Logo
109 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
