Question about Microwave Ovens
Samsung MXGR45 Microwave oven
Hello, The above microwave as had no problems until now,
It has started to switch it self on its own and sparking and arcing
if you switch it off its ok for a few hours then it starts all over again.
all so some of the touch buttons dont work.
Thanks in advance for any help you may give.
  • Microwave Ovens Master
  • 9,098 Answers
The arcing is often due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
The reason it turns itself on and some keys don't work is that you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can get Samsung parts here.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
I have G273v samsung microwave. can i bake a cake in that
Yeast will not rise using conventional microwave oven type energy. So, you can't have your microwave and eat it too ... (groan - sorry)
Apr 02, 2015 | Samsung Microwave Ovens
Microwave not heating
Hi Edward
I should mention (although it's pretty obvious) that Microwave Energy is DANGEROUS.
So it's better not to fiddle with the internals.
A quick test can be done to check for electromagnetic energy (in the 2.45Ghz range) inside the oven. Put a glass of water in the Microwave Oven and place 2 strips of tinfoil across the top of the open glass above the water. Put the strips close together but not quite touching then close the door.
Start the microwave & look through the glass window. Listen & Watch for sparks between the tinfoil pieces. If there are sparks then your Microwave Oven is generating or transmitting electromagnetic energy from the magnetron tube unit.
If it's working Don't leave it sparking too long. The tinfoil can get hot enough to burn. The glass of water is to absorb any microwave energy.
There is an interlock switch on the door for safety to protect you from microwaves leaking out of the door cracks. This switch fails to function sometimes. But normally the oven won't even try to power on or spin the turntable (or Fan) if this interlock fails.
If there are no sparks then your Magnetron is shot. Its usually not worth fixing them unless you know of a specialist technician who is qualified and competent with microwave equipment.
Hope This Helps
..... Trevor
Jul 15, 2014 | GE Profile Spacemaker Over-the-Range...
How to unlock the samsung microwave
Setting the Child Protection Lock
You can lock your microwave oven so it can't be used by unsupervised
children.
1 Press the My Choice Button and the 5 button at the same time for
3 seconds.
The display shows : CHILD LOCK ON.
2 The display returns to the time of day.
At this point, the microwave oven cannot be used until it is unlocked. To
unlock it, repeat steps 1-2 above.
May 19, 2014 | Samsung SMH7178STD Microwave Oven
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Need a manual.
Hello.
The name of the oven is need to solve the problem as do it your self offer and also the serial number of the microwave oven will also be needed .
Get all the above instruction reading from the receipt or on the body of the oven the visit the below address to get your self a user manual.
oven user manual guide .com or operating manual guide .com
Thanks.
Sep 03, 2011 | Microwave Ovens
Newly installed GE profile pem31 microwave starts as soon as plugged in and won't clear or shut off with the key pad. It is not heating but light is on and making noise.
hello,
this is a simple function that you should be able to carry out your self
from the statement above this means that your oven maize have disconnect from the element position i.e the wire have been disconnected from the heater
what you need to do is that unscrew your microwave trace the wire to the heater you will surely fine were the wire is been disconnected from the heater
then you have to huck up the wire back to the element (heater) the wire mention above will be in red and others can be in different color
please when doing make sure that all form of power supply is disconnect from the microwave to avoid accident
thank you and thanks for using fixya.
May 02, 2010 | GE Profile Spacemaker II PEM31 Microwave...
Microwave is turning itself on
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME, at night, while you are away, at work etc. Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&E out to fix it. Although it will fix the problem, if the keypad fails again, the self start logic defect is still present. You should be under warranty if it is above model. I almost had a fire this past Monday, Labor Day, 9/7/09 when my machine self started at 3 AM with a package of bacon left in to thaw for the morning. What a somey mess. Chinese made garbage.
Aug 19, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave starts after plug-in cannot be stopped by control panel
This seems like a problem with with the door latch circuitry HW. If the unit is still in warranty, call GE customer care. If not, your neighbor will need to buy a new oven. Service on microwave ovens is not cost effective because the replacements are so reasonable and have so many new features.
I have a lot of experience with these units. If the door latch circuitry is in question you may be exposed to dangerous microwave energy. Hope this helps...
Ray
Nov 20, 2008 | GE Microwave Ovens
WHEN SWITCHED ON MICROWAVE RUNS FOR 22 SECS AND THEN CUTS OUT ....
possibly a self-diagnostic service that detects a non-functioning magnetron
May 28, 2007 | Siemens HF26066GB 1000 Watts Microwave...
Microwave Ovens Logo
121 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
