Question about Minolta Office Equipment & Supplies
Hello, Our Minolta Dialta Colour Copier/Printer CF 2002 has come up with a "C-0208" malfunction right after the maintenance contract expired... Can anyone help, please?
  • drogers610 Aug 14, 2008
    Hello Wayne,
    Thanks very much for the tips.
    We popped out the image units and checked the contacts.
    After reinserting, the error message changed to C0204
    I believe that this is "Yellow PC Drum Charge Corona malfunction" which seems to suggest that the yellow image unit is the problem?
    Can't see anything wrong with the contacts, however. Should we just change the image unit it or is there something in the unit we can check/clean/other?
    Thanks.
    Dave.
  • 300 Answers
C0208: PC Drum Charge Corona malfunction. The SCD signal is detected for a continuous 0.7-sec. period while the PC Drum Charge Corona is being energized.
Relevant Electrical Parts - Image Units C/M/Y/Bk, High Voltage Unit (PC Drum CH.) HV1 IO Board (PWB-IO)
Steps (in this order) - Check the Image unit contacts and correct
or clean as necessary.
Check the HV1 contacts and
correct or clean as necessary
Change Image Unit.
Change HV1.
Change PWB-IO
Posted on Aug 13, 2008
  • wayne churchill Aug 14, 2008
    The last one i did, i ended up having to change the image unit. Just make sure the toner isn't empty first.
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
Cob08 error
If your copier is Dialta 250 reset the malfunction code.
Push the warm restart switch located on the right side to control panel in area of display contrast knob(hole) and enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screenis being displayed.Select the trouble reset and touch exit.
Feb 11, 2013 | Minolta DiALTA Di250 All-In-One Laser...
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
Printing #10 Envelopes in a Minolta CF 2002
You can print #10 envelopes in ANY printer. Use the bypass (or multi purpose tray).
May 04, 2009 | Minolta CF2001 Copier
Copier proplem
1. Reset the malfunction (i.e., turn OFF and ON the Power Switch).
or 2. If the same malfunction is still detected, check the EDH harness and, if it is okay,
change PWB-IB.
Feb 01, 2009 | Minolta DiALTA Di520 Laser Printer
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta cf910
Hello sir; Press "trouble reset switch" ,open front door you will find that switch.
Jun 30, 2008 | Konica Minolta DiALTA CF910 Copier
Minolta dialta di520
problem code c1039  for d-i 620
May 10, 2008 | Minolta DiALTA Di520 Laser Printer
353 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
