Question about O2 Xda IIs Pocket PC
O2 xda iis
My problem is that my o2 xda iis unit, when being charge the buttery got hot then it will go to the side of the body, then the body will get hot when u fully open the power, but when you charge and it stays in the stndby mode the buttery does not get hot. same as thru after it is fully charge, when you open the power in fully open mode then the buttery will get hot untill it will spread to the body. the screen has no backlight, i try to reset it just flash or blink then nothing, no back light. i hope u can help me solve my mproble so i can enjoy my O2 xda IIs again. thanks
Just throw it away and try to buy another 1
Posted on Oct 21, 2008
    Problem Solver:
  • 5 Answers
Sorry yur power ic is damaged just replace this ic yur phone will work properlly...
Posted on Sep 26, 2008
Hi i plug unit with battery for charging no display lcd and no light indicator colored orange . I take out battery pack and charge then it produce light orange-red indicator of unit. I noticed charging...
Hi I solved the problem by taking off the battery for around 1 hour.
I attached the battery again.
And press hold switch around 10 seconds.
The unit booted and it proceeded to auto configure and auto installed program soft wares.
I realized that the unit is self shutting off.
Solution is go to setting.go to system.go to back light menu.
on backlight on external power .Be sure to uncheck turn off backlight if devise is not used for 1 minute.
Be sure to check turn on the back light when button is pressed or the screen is tapped.
press ok to activate the setting.
For maximized battery power and optimized power usage .go also to back light and go to brightness level.
Slide the battery and power to almost the 2ndlevel .
Hope this also will be applicable to other o2 xda iis configuration.
Best regards
Jan 17, 2010 | O2 Xda IIs Pocket PC
XDA IIs hangs and will not start
Probably got a DOA unit. Most ebay sellers allow exchanged or refunds for DOA products within a certain timeframe of purchase.
Otherwise, I would try taking out the battery and leaving it overnight to drain everything inside fully then trying again. If it hangs it is most likely hardware/software and not battery.
Jan 18, 2008 | O2 Xda II Smartphone
About Xda mini o2 problem, how can i now if my cellphone is fully charged?
tap on the battery icon you can see the percentage of battery charged, on charging orange light turns to green when battery is full.
Oct 26, 2009 | O2 Xda II mini
Screen on my O2 mini xda II doesn't work; hear the program works but the screen is completely white.
if your unit has been dropped or been in your paocket and got wet by perspiration/sweat, you need a new lcd module. buy a new one and have it installed by a certified technician.
May 19, 2009 | O2 Xda II mini
IC Power
1st check yur charger if yur charger is ok then check the charging socet if both ok then change , resold , or reball the charging ic it will charge properlly
Sep 19, 2008 | O2 Xda IIs Pocket PC
PDA displays only a white Screen
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
O2 XDA Zinc
How to hart reset or formating O2 Xda Zinc
Jun 03, 2008 | O2 Xda IIs Pocket PC
O2 xda formatting
Quite possible the upgrade failed and has corrupted something.
You will need to find out how to perform a Cold reset as this should return it back to factory defaults.
See here for some assistance.
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
Apr 24, 2008 | O2 Xda IIs Pocket PC
No backlight, the body always get hot every time i recharged the unit
change the settings for the backlight.. just go to start>Settings>System>Backlight and use the tab to go to next page and there will be the setting for the backlight while on charge. Just move it up to desired lighting and there your done.
Mar 20, 2008 | O2 Xda IIs Pocket PC
O2 XDA ii screen does not align
how to align screen xda ii
Mar 12, 2008 | O2 Xda II mini
O2 Xda IIs Pocket PC Logo
90 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
