Question about Zanussi IZ12 Front Load Washer
Zanussi IZ12 Type P6747639 how to reset or program new card?
I have changed the mother board of this washing machine but it is still not programmed? How can I program it?
3 Suggested Answers
SOURCE:
  • 1462 Answers
SOURCE: Where can I order a new belt for my Zanussi IZ12 wasmachine?
bit of a nuisance doing it from afar but i have used currys masterpart ( a uk site) for ordering spares now i'm retired
Posted on Nov 12, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi IZ12 mid program door light comes on.
E40 is a door interlock fault, it is either faulty or the wiring between it and the main board is at fault,
Only way to open door is to remove top cover, and try to force the door open from the inside, if you can see the door latch, try pushing it with a screw driver or something to release it, worst case scenario, is you will have to break the lock to release the door.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Error e51 on zanussi iz12
Dec 07, 2009 | Zanussi IZ12 Front Load Washer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
Thanks.
Jan 31, 2009 | Hotpoint WMA30 Front Load Washer
Nov 12, 2008 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Zanussi IZ12 Front Load Washer Logo
145 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
